Question for you guys about engine Temp! - Ford Powerstroke Diesel Forum
post #1 of 1 Old 03-22-2013, 05:31 PM Thread Starter
stealthrunner's Avatar
Quoted: 2 Post(s)
Question Question for you guys about engine Temp!
Ok here's what i was doing...had the truck hooked up to AE on a drive to the shop i play at...AE said that the truck Engine temp was above normal when i got to the shop AE said the temp was about 250 degrees... and the temp gauge on the dash said it was in the center of the normal range????When i got to the shop i used a laser Tempature gun and the rad was about say 180 degrees-ish and nothing was as hot as AE told me????WTH????
95 F-350 4x4 Crew Cab
Mods. so far
DIY Intake
4" diamond Eye exhaust
New Toyo AT 2's
VHF/UHF Radio
Pillar gauge pod and all Isspro gauges
E-Fuel done and running!!!!
Wicked Wheel 2!! Good Mod.!!
Intercooler is in and helps alot!!!!!
100 Gallon transfer tank...
Stage 1's and a Hydra chip with tony's tunes on it!!!
Next on the list...ZF-5 swap...
stealthrunner is offline
