Truck temp hot when pulling???? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-22-2013, 06:30 PM Thread Starter
Hey guys,
I have a friend with a 95 f350 and his truck runs hot when he pulls his camper... Well we thought it might be his fan clutch so we replaced it and nada... So we asked a shop about radiator and he said they rarely fail or need replacing... Do the oil coolers on these truck ever fail or need cleaning? I have a 6.0 so I not familiar with the older 7.3..He don't have any gauges he is just going off the factory temp gauge.. Without pulling it shows below N and when pulling it gets past the AL.. Any advise ???
Thanks
Bloodstain is offline
post #2 of 6 Old 03-22-2013, 06:53 PM
Quoted: 80 Post(s)
Feedback Score: 4 reviews
Try swapping in a 6.0 fan. I would also check what the engine temp actually is, the dash gauges aren't all that accurate.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #3 of 6 Old 03-22-2013, 07:23 PM
jesilvas's Avatar
Quoted: 2 Post(s)
May have a bad temp sender, dirty radiator, bad water pump, dirty cooling system, worn out coolant.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 6 Old 03-23-2013, 03:34 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Full of coolant?
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 6 Old 03-23-2013, 05:34 PM
dr.deere's Avatar
Quoted: 19 Post(s)
Also would maybe try replacing the belt if its slipping it won't drive water pump or fan fast enough. Had that same issue once turned out to be belt
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #6 of 6 Old 03-23-2013, 05:52 PM Thread Starter
Thanks guys.. This site is awesome like always.. When we find the culprit ill post it up.. Thanks again
