Found a 97 F350 CCLB I couldn't pass up!! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-22-2013, 06:28 AM Thread Starter
I found this one for $3K with 300K on the odometer and 86k on new engine put in by ford and i have the invoice from it when it was done. its stock, nothing done to it besides missing a cd player, but i cant complain. here are some pics.
2003 F350 7.3L Lariat FX4
05-07 badges
05-07 front conversion
casserly stage 2 165cc injectors
srp1.1 hpop
gtp38r (should've done h2e
custom 6 position chip
isspro ev2 gauges
6inch lift
4inch Straight Pipe
Mt's 37x13.50 R20
3.73 gears
billet converter
48 gallon fuel tank
08 Front and Rear Axles
plus more.....
soon to come: bts trans.
swalker332 is offline
post #2 of 3 Old 03-22-2013, 08:55 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Not bad at all on the motor aspect, looks like a good rig ya got there
Is that a 4x4 hub and u bolts on a leaf spring I spy?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 3 Old 03-22-2013, 03:52 PM Thread Starter
you see well. yep 4x4. now its time to tear into my 03 and do my 05+axle swap in that
05-07 badges
srp1.1 hpop
isspro ev2 gauges
6inch lift
4inch Straight Pipe
Mt's 37x13.50 R20
3.73 gears
billet converter
48 gallon fuel tank
plus more.....
