Powerstroke swap - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-21-2013, 09:58 PM Thread Starter
bigred69's Avatar
Powerstroke swap
I'm currently in the process of swapping my 76 F-250 cab onto my 96 bronco chassis which is being fitted with 95 F-350 running gear from the engine down to the axles. I'm using a 4" shackle reversal/flip and 3" body lift and running 37/13.50 Toyo M/T's on 20" rims... now here's my problems. I need a PCM and IDM as well as a set of 20" used wheels. I could also use a gauge cluster with tach. if someone has one layin around. This is my ultimate budget build. I probably only have 2k$ in the entire project. I'll take some pics tomorrow. If ya'll have anything I can use let me know. I can come up with money but I love to trade! Lots of ford parts including a complete 96 Bronco body in good shape front clip and all. 95 5.0 backed by a 5-speed and a 93 4.6 dohc from a mark vIII(teksid block) Let me know what you think and send me a pm if you can help me out!
BIGRED69
7.3 Powerstroke (conversion in progress)
"IN GOD WE TRUST"
bigred69 is offline
post #2 of 3 Old 03-22-2013, 11:25 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Sounds like a fun build, subbed for piks and good luck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 3 Old 03-22-2013, 11:29 AM
JJFLASH's Avatar
Quoted: 111 Post(s)
Yup. What he said
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
