vacuum sound - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-21-2013, 03:25 PM Thread Starter
dieselduff's Avatar
vacuum sound
Im having this issue were my truck is making a vacuum sound when i accelerat, i have had this sound ever since iv had the truck but when i started it it would make the sound for about 10 seconds and cut out then it would spool and make that beautiful whistle sound, my problem is this sucking vacuum sound doesnt go away anymore and it sounds like carp. Anyone know anything??
dieselduff is offline
post #2 of 10 Old 03-21-2013, 03:28 PM
erics diesel's Avatar
sounds like your ebpv is partially stuck shut. have you noticed a lack of power when it does it?
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 10 Old 03-21-2013, 03:45 PM Thread Starter
dieselduff's Avatar
No it still has the sam amount of power when i stomp on it it goes away and spools hard but when im at a steady rpm its starts again
post #4 of 10 Old 03-21-2013, 04:09 PM
speedracer7c's Avatar
Sounds like stuck ebpv. My truck did this too. Unstuck it no more vacuum sound.
97 F350 Reg cab XLT 7.3, ZF5 Swap, Diamond eye 4" turbo back,Riffraff 6637, Deleted pedestal and outlet, riffraff billet wheel, Baby Swamps, Ts 6 pos with swamps tunes Glow shift triple gauge pod
340k miles and kicking!
2016 F-250 Supercab 6.7
speedracer7c is offline
post #5 of 10 Old 03-21-2013, 04:23 PM Thread Starter
dieselduff's Avatar
Ok ill try it out how exactly to i do that? Were is it located exactly?
post #6 of 10 Old 03-21-2013, 04:35 PM
dr.deere's Avatar
Quoted: 19 Post(s)
vacuum sound
The Ebpv is on the outlet of the turbo exhaust side. Has a rod that runs from it to the pedestal. Should be all the way towards turbo to be open
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #7 of 10 Old 03-21-2013, 05:18 PM Thread Starter
dieselduff's Avatar
From what i here there is a sensor of some sort on it if i unplug that will it open or if i cut the power to it will it remain closed. Correct me if im wrong
post #8 of 10 Old 03-21-2013, 05:20 PM
on the drivers side of the turbo pedistal you will see a 2 wire plug un plug it and it will not activate again. just make sure it is open when you do it and i would wire the rod open so it can't close again
post #9 of 10 Old 03-21-2013, 05:29 PM
i popped the rod off mine. Its been fine that way.
post #10 of 10 Old 03-21-2013, 05:29 PM Thread Starter
dieselduff's Avatar
Cool, thanks alot guys
