Fuel flow Question - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-21-2013, 01:10 PM Thread Starter
Fuel flow Question
Greetings,
I wish to instal a Racor fuel filter / water separator, and an electric lift pump
on the frame of a new to me 1996 E350 van with a 7.3. Why? Because accessing and servicing the pump assembly in the valley is a nightmare.
So the question is: How much of a fuel flow can I expect when I cut the fuel line to make the installation, or should I just drain the fuel tank before proceeding?
Thanks in advance for any help.
Dick
tartansailor is offline
post #2 of 2 Old 03-21-2013, 01:30 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
We don't have a lift pump, you can do an electric fuel conversion however, just search the numerous e-fuel build threads, good luck and welcome to the org
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
