Time to Replace Clutch... - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-21-2013, 08:30 AM Thread Starter
s54mcoupe's Avatar
Quoted: 2 Post(s)
The throw-out bearing on my clutch has died, but I want to replace everything while I'm working on it.
Does anyone have reccomendations? My truck will be hauling around 6-7k lbs almost constantly for the next year, so I'd like to get a setup that replaces any weak links in the OEM setup.
I've gotta get all of the parts sourced within the next week so I can have my buddy help me with the repair. If anyone has ideas/links on the best places to source everything, that would also be rad.
My girlfriend and I are spending the year on the road (we've got a Lance on the bed of the OBS) but we're spending the next 2 weeks at an address where I could have parts shipped if ordering online is the best idea.
Thanks in advance for any advice/links/ideas!
s54mcoupe is offline
post #2 of 13 Old 03-21-2013, 09:37 AM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
get a single mass flywheel conversion from valiar, luk or southbend. I got a upgraded southbend from thoroghbred diesel outta ID. best price i found. also get more clutch than you think you need
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 13 Old 03-21-2013, 09:39 AM
the baconator
Quoted: 141 Post(s)
link to the southbend clutches they also stock valair
South Bed Clutches 94-97 Powerstroke 7.3L
post #4 of 13 Old 03-21-2013, 09:45 AM
Quoted: 43 Post(s)
+1; Dumb-mass... er... dual-mass flywheel is THE MAJOR weak link in the OEM. The other, minor one is the fork; there's a TSB out there describing an issue, and Ford has an improved version for not too many dollars.
madpogue is online now
post #5 of 13 Old 03-22-2013, 11:53 AM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
madpogue, do you have the TSB number for the fork issue (I thought it was an SD issue). That being said, I always replace the fork anyway since it's only about $20. Cheers!
Patrick Feeley is offline
post #6 of 13 Old 03-23-2013, 12:40 PM Thread Starter
s54mcoupe's Avatar
Quoted: 2 Post(s)
Awesome, thanks for the help guys! I ordered a south bend -looking forward to getting it on.
Anyone have a good place to buy a clutch fork (specifically supporting vendors of powerstroke.org, or businesses worth supporting?)
Thanks again!
post #7 of 13 Old 03-23-2013, 03:32 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
I would recommend a Valair Organic. It is $100 cheaper than SB, customer service is excellent and I have had it in my truck for 2 years with Zero issues. I gross out around 20,000lbs and have aprox 325hp
Performance Clutch - Ford PowerStroke
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #8 of 13 Old 03-23-2013, 08:19 PM
Quoted: 8 Post(s)
Get a stock one from Tousley Ford Parts online:
Clutch, Release Lever
(Ford) E7TZ-7515-A
Cheers!
post #9 of 13 Old 03-24-2013, 12:15 AM
Quoted: 43 Post(s)
Argle bargle for some reason I can't find the TSB on the fork now.
post #10 of 13 Old 03-25-2013, 06:04 PM
stroken96's Avatar
will the fork issue make third gear grind unless you shift real slow? All my other gears go in great but third. sorry not trying to steal your thread just thought id ask since this is a tranny thread.
stroken96 is offline
