Diesel newb from Cal - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-20-2013, 08:58 PM Thread Starter
Arcturus's Avatar
Hi folks, I don't own one yet but am in market for a 95-97 PSD. Of the trucks form these years are any better than the others? I will be looking at one this weekend, a 1996 with about 90,000 miles on it. I am willing to pay a premium for the low mileage because at this point I know zilch about diesels and don't want to encounter problems I might find on higher mileage one.
I don't think I will be too many if any mods to except the 6637 and the 3" downpipe changes.
Is there anything you can think of that I should check out in particular when looking at used trucks with fairly low mileage?
Anyway, looks like a good forum with good advice can be found here.
Oh, is there a better place to ask these questions on the forum?
Thanks
JackT
Arcturus is offline
post #2 of 11 Old 03-20-2013, 09:17 PM
boozinag's Avatar
Welcome. And no, I ask questions in general too as it gets the most traffic. Of the Powerstroke forums I have visited, this one is by far the best for newbs. The members answer my stupid questions without acting like I am an idiot.
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #3 of 11 Old 03-20-2013, 09:21 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Your in the rite place, welcome to the org,
Check turbo fins for dusting, check oil cap for blow by by flipping it over, smell trans dipstick for burnt smell, look for leaks on top and under, test drive it, and what cal California or Calgary?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 11 Old 03-20-2013, 11:09 PM Thread Starter
Arcturus's Avatar
I live in the SF Bay area of California, the truck will be used to tow a mid size Kubota tractor but also my everyday driver. In California the 97 and earlier PSD's do not need to be smogged. a big plus and kinda surprising in that this is Kalifornia.
Thanks for the tips for things to look for.
The dusting you mention is that a residue from running too hot?
Arcturus is offline
post #5 of 11 Old 03-21-2013, 02:02 AM
Justin@DP-Tuner's Avatar
Quoted: 52 Post(s)
Good advice.
Dusting of the turbo(and engine too) is from unfiltered air being let into the turbo. This will wear down the fins on the compressor wheel and get into the cylinders where it will damage the rings/cylinder wall.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #6 of 11 Old 03-21-2013, 07:12 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
^^^ that, and Check out wcs thread, west coast strokers, I live down in San Diego the no smog is nice
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 11 Old 03-21-2013, 10:57 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 45 Post(s)
Crap, another No. Cal Diesel (in the making ). '97 Cali's had an injection set-up closer to the SD (Super Duty's) from '99-03. A little more power then the rest of the OBSs but with that comes the price of having some one off parts that are expensive to find and replace( I.E. the '97 Cali PCM is worth gold) '96 and '97's came with a different HPOP (that's High Pressure Oil Pump, you'll pick up acronyms quick around here) that is more desirable as the oil return is more like the SD set-up making them easier to get aftermarket. Late '94.5 and '95's have a different HPOP and front cover. Not hard to find parts but you have to know what you need and not just buy parts willy-nilly.
Do the checks that Kris mentioned, leaks in the engine valley are kinda easily fixed and leaks under the truck are somewhat time consuming. Not really deal breakers to me. These engines have a drain hole in the back of the engine valley that drains down the back of the motor and exits either under the trans (making it look like a rear main seal leak) or over by the starter (making it look like you have a High Pressure galley plug leak. Both are usually leaks from the turbo pedestal. Expect a $300 R&R bill to have a shop fix that. Just because it has low miles doesn't mean that it was treated nice. If you flip over the oil fill cap and the motors internal gasses blow it off the fill tube you are looking at good (as in bad) cylinder blow-by and a hefty engine repair bill. Walk away and don't look back....
Tuners like Justin above are totally willing to answer your coming power questions and please buy from our sponsors as if they don't see a reason to be here we loose their support. When making a purchase let them know you are from the ORG and I often get a price break.
Ask a question anywhere and if you feel shy about a particular question up above this thread is a newb free-to-question thread. One thing though and this _might_ be considered a warning from a Moderator. DO NOT ask "how do I make my truck smoke" like those a$$hats on YouTube. We do not support this smoking crap.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #8 of 11 Old 03-21-2013, 12:37 PM Thread Starter
Arcturus's Avatar
Good info here. Thanks
I assume you do this with the engine running?
Not at all into that, maybe just a train horn
I can see why this site is so popular. Thanks for the help. I hope to post up pics of my PSD when I find the right one.
Arcturus is offline
post #9 of 11 Old 03-21-2013, 01:12 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 45 Post(s)
Sorry, yep with the engine running. If possible don't let the PO start the truck before you get there.
Train horns, how childish
These are only 16" & 18" long. I've got a 4.5' horn in the garage that I need to find a new diaphragm for then that goes on.
Matt
'97
-Stage II trans.
BigFuel is offline
post #10 of 11 Old 03-21-2013, 02:16 PM
boozinag's Avatar
I need train horns. I almost got sideswiped last week by some sorority girl who was texting and driving with her music up. It is a big problem in my town... Texting and driving that is.
Gerry
184k
boozinag is offline
