Issues with heat - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-19-2013, 08:27 PM Thread Starter
Issues with heat
Hey all this is my first post to this site, but I am sure it wont be my last, I have a 12' 350 DRW KR with the 6.7 and love the hell out of that truck. However I came here because a friend of mine has a 97 7.3 350 DRW that he just picked up. It already has an aftermarket trans cooler, turbo down pipe, airbags, pyro meter (not sure location of meter) and from what I can tell a mild exhaust. Here is where my knowledge on these old guys fade away...when he runs stock pulling nothing he is around 800 degrees...that seems a little hot to me. When he pulls his 5th (14K lbs)..I know a little more than ford spec, he is already toying around 1200 degrees at 45 MPH. This is all on a stock tune. This seems odd that it is running this hot. What could be going on here?
RyRoRyan is offline
post #2 of 4 Old 03-19-2013, 08:44 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Restricted stock intake? Or clogged filter, that is very heavy still in any event, seems like an ic would help your friend dramatically, is he down shifting out of od as well? And welcome to the org, you should get your friend to join too
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 03-20-2013, 01:55 PM Thread Starter
After market K&N, clean as a whistle. I dont think he wants to dump the $$ into an IC. I mean for running at 800 on flat road in 60 degree weather, I/we have to think something else is up.? He put in a TS Switch Chip and set it to 50HP and it did not change a thing, well power wise it did, but temp wise nada. I am lost.
RyRoRyan is offline
post #4 of 4 Old 03-20-2013, 02:01 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Boost leak or exhaust leak (pre-turbo). Probe placement is important but with that said probes don't last forever. Borrow a IR thermometer and hit the manifolds to see how close they are to each other. 1200* is entering danger zone.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
