International 4700 for upgrades? - Ford Powerstroke Diesel Forum
post #1 of 30 Old 03-18-2013, 03:49 PM Thread Starter
boozinag's Avatar
International 4700 whole or parts
Any parts I could get cheap of this engine that would be an improvement over my stock motor?
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #2 of 30 Old 03-18-2013, 04:08 PM
Quoted: 3 Post(s)
Did they come with ac code injectors?
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 30 Old 03-18-2013, 04:16 PM Thread Starter
boozinag's Avatar
according to international the water pump, PCM, fuel pump, and turbo are different. Does not get specific on the turbo.
Any info on the turbo? any reason why I would want that over my stock turbo?
Gerry
184k
boozinag is offline
post #4 of 30 Old 03-18-2013, 04:19 PM
the baconator
terryknight's Avatar
Quoted: 150 Post(s)
water pump may have a screw on filter. will bolt on the psd, but we require changing the radiator hoses around
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #5 of 30 Old 03-18-2013, 05:46 PM Thread Starter
boozinag's Avatar
What about the injectors in it?
Gerry
184k
boozinag is offline
post #6 of 30 Old 03-18-2013, 06:38 PM Thread Starter
boozinag's Avatar
Some preliminary research says if they are any good the AC code injectors are basically stage 1s. To get the full benefits of those injectors I am guessing I will need some custom tunes, correct?
Gerry
184k
boozinag is offline
post #7 of 30 Old 03-19-2013, 02:05 AM
whistlin dixie's Avatar
Couldn't tell you if there basically a stage one but yes if they are bigger your gonna need tunes to get full effect out of them.
Sent from AutoGuide.com App
Zac
97 F-350 sclb
3" dp 5" exhaust
6637 intake
ts chip tw tunes
rosewood stage 1's
cali to 49 state PCM swap.
American Racing AR23 wrapped with 265/75 General Grabber AT2
20% window tint
Tinted taillights
Kenwood headunit
Kenwood speakers all the way around
8" kicker subwoofer
whistlin dixie is offline
post #8 of 30 Old 03-19-2013, 02:18 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Check the HP rating of the motor on the valve cover. There will be 3 and one will be punched out. The highest HP one is the AC code injectors (stage 1s). The turbo is the same i think but the pedestal and turbo outlet are different. It had a deleted pedestal and deleted housing which is desirable to add to your truck. It will have a 7.3 to SAE 2 bell housing adaptor which can open your trans options if u ever want to put an Allison behind your 7.3. There will also be n intercooler spider that can be modified to work in an OBS with a little effort. 1000 bucks for thw whole truck??? Id pick it up.
If your lucky it may have the power steering pump aboue the HPOP which u can turn into a DIY GEN3 HPOP if u want with some modifications and it has air bakes will come with a belt driven York air compressor on it.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #9 of 30 Old 03-19-2013, 07:12 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Now that sounds worth it, hell the motor can go for what the whole truck is gonna cost
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #10 of 30 Old 03-19-2013, 10:47 AM
ol_Blue97's Avatar
Yup... i got a T444E motor sitting in my yard as we speak. Actually is a complete nose off a buss. Complete with all the goodies, including the york compressor.
FRANK THE TANK
