5th Wheel Questions - Ford Powerstroke Diesel Forum
post #1 of 33 Old 03-16-2013, 03:45 PM Thread Starter
svranger25's Avatar
5th Wheel Questions
Hey guys, just bought myself a 5th wheel RV i'm gonna be pulling around, hitch should be in sometime this week, then i can go snag the trailer, questions are, where is everyone mounting the 7 pin plug in the bed? any spots better than others? What kind of brake controllers are ya'll using? i plan on getting a proportional controller, what brands are good but not gonna blow my wallet, under 100? Just using the factory plug and an adapter off amazon. Hopefully getting the axle fluid changed soon? recommendations on fluid? any other things i need to look into, trailer is around 11k not heavy but not a light one either. thanks
-Brandon-
1996 F 350 7.3L CCLB
6637 Intake; Banks: Intercooler, Up Pipes, Turbo; PHP Phoenix
4" down-pipe, cat delete,muffler delete, 4" turbo back exhaust
Sky Jacker Suspension, Limo Tint, Cobra Classic 29 LTD,
Stage 2 TC, improved internals
Loudest, Proudest member of the Fightin' Texas Aggie Class of 2015!
svranger25 is offline
post #2 of 33 Old 03-17-2013, 08:43 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
I have my plug mounted in the bed just in front of the driver's side wheelwell. I use an older Tekonsha Voyager brake controller. I can't recommend a different one since I've never used some of the newer ones (say like the Tekonsha Prodigy). Maybe some others will chime in on their likes/dislikes as far as that goes. I would recommend a synthetic 75W-140 for the rear end (I use RedLine). Cheers!
Patrick Feeley is offline
post #3 of 33 Old 03-17-2013, 08:47 AM
toad's Avatar
Quoted: 16 Post(s)
Prodigy is awesome
toad is offline
post #4 of 33 Old 03-17-2013, 08:57 AM Thread Starter
svranger25's Avatar
I like the price of the voyager much more than the prodigy as long as it gets the job done.
-Brandon-
post #5 of 33 Old 03-17-2013, 11:51 AM
mkeith54's Avatar
Prodigy works much smoother than the voyager, I've got the prodigy in my truck and the son has the voyager in his. To me the difference is worth the extra cost. My plug is in the inner wall of the bed just aft of the wheel well. Makes it easy for my wife [a short person] to reach.
Mike Keith
New Florence Mo
1996 F-250 ECSB, 6-pos/ts chip/ Tymar intake
Pyro, boost, and tranny gauges
mkeith54 is offline
post #6 of 33 Old 03-17-2013, 02:53 PM Thread Starter
svranger25's Avatar
I will look into the prodigy then, i'm also going to be looking into some towing mirrors as my little nemo mirrors aren't going to cut it, pretty of threads on this,
-Brandon-
post #7 of 33 Old 03-17-2013, 03:27 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I have slip on tow mirrors over my nemo's think they cost like $25 bout 8 years ago, I see them on Craigslist from time to time tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 33 Old 03-17-2013, 03:45 PM Thread Starter
svranger25's Avatar
you think they are enough to see around a 35' fifth wheel? i was thinking swapping to the four points if i can find a cheap set.
-Brandon-
post #9 of 33 Old 03-17-2013, 03:59 PM
Quoted: 5 Post(s)
The prodigy is niiiiice
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #10 of 33 Old 03-17-2013, 05:24 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
They work good for me, best length I've pulled with them is about 20-25 feet tho, going to a different truck to start pulling with and gonna use the factory 08 mirrors I got on the floor of my garage
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
