Engine removal 96 F350 7.3 - Ford Powerstroke Diesel Forum
post #1 of 17 Old 03-15-2013, 09:23 PM Thread Starter
I have to swap out the engine on my 96 f350, and can find some info on the 99 and newer pickups, stating that you remove everything from the front of the pickup and then lift and slide the motor out over the bumper. Can you do the same on the 96 model and if so how do you go about it? I got a Chiltons for it, and it doesn't say squat. In fact it said the fan clutch had a left hand thread, when it is a right hand thread. Not impressed with the manual. So hoping for some input and info on taking that beast out.
Tinkerdeux is offline
post #2 of 17 Old 03-15-2013, 09:40 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Pull everything in front of it, header panel, radiator, core support, bumper, gap guard, headlights, turn signals, literally everything in front of the fenders, unplug all harness' and well I took the hood off and went up and over on a 95, but you won't have to re align this way explained, but it won't be quick and easy either way, don't forget the trans (6 bolts) and motor mounts as well
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 17 Old 03-16-2013, 08:16 AM
dr.deere's Avatar
Quoted: 19 Post(s)
It will come out if you pull hood and radiator have to lift higher but it does fit that way
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #4 of 17 Old 03-16-2013, 09:21 AM
Diesel_brad's Avatar
Quoted: 4 Post(s)
if toy are anywhere near rust, do NOT try and remove the core support. Just take the whole nose off the truck and plan on new rad support bushing and bolts
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 17 Old 03-16-2013, 12:51 PM
JD3020's Avatar
I just did this, i've got my new engine on the stand right now actually. Original plan was to pull the core support, but it was so bad that i left it in. We pulled the engine right up and out of the engine bay. All that really needed pulled out was the radiator and hood. Extremely tight fit though! Now at one point the engine did shift and dinged up the windshield wiper motor, but it wasn't in great shape to begin with so no biggie there.
Biggest challenge is finding something to lift it with. We have a forklift so it was no big deal, but you need something heavy and that can lift high if you leave the core in. These things are beasts! And Bill(alberta7.3) gave me a good tip, just remove the 2 nuts on the engine mounts under the crossmembers. Some write-ups say to unbolt the mounts from the engine, but if you take the nuts off it will lift up and out.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #6 of 17 Old 03-16-2013, 02:51 PM
7.3powerstroker's Avatar
I just did it too. No need to pull the support. Pull the rad and hood. Then as your lifting it out when it's about halfway out turn it to the right (if your standing looking at the front of the truck). Turn it 90 degrees and she should come right out. I used our bobcat to lift mine out. Worked amazing. Just gotta be steady with the pedals lol
Sent from AutoGuide.com App
Shelby
1995 F350 7.3l
5 speed
240,000km
DIY Intake
3.5"dp to 5" straight pipe
99 Turbo and Spyder
6" Lift
37" BFG KM2's
Harley Davidson Leather buckets
Grant Steering Wheel
Autometer Gauges Pryo,Boost
CB Radio
Custom Bumper(built it myself)
Clear Headlights (black background)
Black Grille and Headlight Trim
Soon to come
Custom Rear Bumper
Headache Rack
6.0l intercooler (already have one just need to pipe it)
rosewood stage 1's
custom tunes
7.3powerstroker is offline
post #7 of 17 Old 03-16-2013, 03:19 PM
dr.deere's Avatar
Quoted: 19 Post(s)
We used a bobcat to put the engine in my 97 when we got it overhauled
dr.deere is offline
post #8 of 17 Old 03-17-2013, 05:46 AM
PSDTV21's Avatar
I pulling my engine too. I ended up taking everything of the front of the truck as already stated.
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #9 of 17 Old 03-17-2013, 08:44 AM
JD3020's Avatar
Must be something in the water here, seems like everybody is pullin their engines.
Jimmy
JD3020 is offline
post #10 of 17 Old 03-17-2013, 11:03 AM
erics diesel's Avatar
Lol. I might be pulling the body off around the engine if I can find rust free parts for the right price
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
