Gauges installed... Now questions - Ford Powerstroke Diesel Forum
post #1 of 31 Old 03-15-2013, 02:49 PM Thread Starter
bignate's Avatar
Gauges installed... Now questions-UPDATED
See Page 2
So I got the Isspro 2's installed today and they are sweet. But...
1. Boost- I'm getting almost none till 2500rpm and from then on not even hitting 10psi. I'm thinking it may be time for a turbo rebuild. It would also give me an excuse to go with the WW2. It ties into the map line with the supplied stuff.
2. Fuel Pressure- It bounces around between 10-20 on idle and makes just under 25 in normal driving. Ideas? I'll post a vid tonight. I had a fuel leak which I fixed by replacing the dashboard sensor sending unit a month ago(silver one on the left). That is where the T is, one side for the dash, the other for my gauge.
3. Pyro- Nothing wrong here! It works great.
4. Glow plug LED- I was surprised to see how long they stayed on after the truck was running.
It makes me laugh that my truck has basically no boost and here I thought that I had alot, cause you can hear it! So with 207k miles on it I'm just starting to get to know it well. Beans Chip will be ordered on Monday...
Nate
1996 F250 4x4 7.3 5 Speed Ex Cab Short Box. Mods: 6637, 3"DP, 4" Exhaust, Beans 6pos Chip, Isspro 2 Pyro-Fuel-Boost, 255/85R16, 216,000 miles
Boost Fooler, 203deg Thermostat and Custom 12" sub center console on the way...
Wishing I was Fishing...
bignate is offline
post #2 of 31 Old 03-15-2013, 04:07 PM
7.3powerstroker's Avatar
Get a mechanical boost gauge. When I had my edge with the screen it said I was only running like 10 psi too. And It would take for ever to get there. I have my line right in the manifold now and I have the proper readings.
Sent from AutoGuide.com App
Shelby
1995 F350 7.3l
5 speed
240,000km
DIY Intake
3.5"dp to 5" straight pipe
99 Turbo and Spyder
6" Lift
37" BFG KM2's
Harley Davidson Leather buckets
Grant Steering Wheel
Autometer Gauges Pryo,Boost
CB Radio
Custom Bumper(built it myself)
Clear Headlights (black background)
Black Grille and Headlight Trim
Soon to come
Custom Rear Bumper
Headache Rack
6.0l intercooler (already have one just need to pipe it)
rosewood stage 1's
custom tunes
7.3powerstroker is offline
post #3 of 31 Old 03-15-2013, 04:13 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
i don't know about the boost, but it doesn't sound right.
fuel pressure is low because the fuel pump is dying. need a new one.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 31 Old 03-15-2013, 04:23 PM Thread Starter
bignate's Avatar
I figured I needed a new fuel pump. now to decide between efuel and the mechanical pump...
Boost is only on acceleration. I took it for another 15 mile test run. Pulling a steep hill in 3rd I hit 15psi of boost. Sounds about right to me for 207k miles.
Can I expect more boost with a tuner than I get now? I'm trying to squeeze every mpg out of my truck while staying with 4.10 gears.
Thanks for the help, Nate
bignate is offline
post #5 of 31 Old 03-15-2013, 05:30 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You will get a lot more boost with custom tunes, and all my gauges are mechanical aside from the hpop, I can get 32+ psi easy
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 31 Old 03-15-2013, 06:31 PM
Phillipjon's Avatar
Quoted: 76 Post(s)
Nate
I have the same gauges and I tapped the sensor into the intake y with great results. Just a thought.
Phillipjon is offline
post #7 of 31 Old 03-15-2013, 06:50 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
You mean you actually installed your gauges finally Phil?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 31 Old 03-15-2013, 07:38 PM Thread Starter
bignate's Avatar
I'm going to leave it where it is for now. Next weekend I will tackle the fuel pump, fuel lines, Y pipe boots, T stat, hoses, and coolant...
Should/will I have to pull the turbo to get the fuel pump out? I'm ok with that, just wondering how big this project is going to be.
Nate
bignate is offline
post #9 of 31 Old 03-15-2013, 07:42 PM
Sam Burton's Avatar
no you don't need to pull your turbo to change the fuel pump
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #10 of 31 Old 03-15-2013, 11:00 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Fuel pump is gonna be between fuel bowl and turbo
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
