Ford F350 automatic Lost Fluid now won't shift properly - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-15-2013, 12:26 PM Thread Starter
jon1882's Avatar
ok i was driving down the road the other day and my alternator locked up shreded my belt and when the belt came off it bent some alternator cooling lines which were then cut by the fan lost all of my Transmission fluid,also pulled off the oil sensor line so my truck shut off and i did not drive it without fluid. I was then pulled the remaining 2 miles to my house without disconnecting the drive shaft. replaced alternator fixed cut transmission lines and reconnected oil sensor line. truck started right up runs fine but the shifting is jacked up i can drive it in D it shifts great i can also drive it in N but it will not shift out of first gear R does not seem to work at all in fact park and reverse seem to do the same thing now lock up and now allow the vehicle to move. i've heard it could be a blockage but that does not make sense to me seeing as how i had no problems with my transmission before also been told it could be an air lock witch makes more sense but i have no idea on how to bleed the system if it is or what needs to be done. any help you could offer would be a great help thanks Jon.
jon1882 is offline
post #2 of 9 Old 03-15-2013, 01:15 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
How fast was it towed with the driveshaft still connected? Where the rear tires rolling, and usually when you pull an auto like that it will tear it up inside, good luck hopefully someone can help better
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 9 Old 03-15-2013, 01:35 PM
boozinag's Avatar
I thought that was safe in neutral?
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #4 of 9 Old 03-15-2013, 02:04 PM Thread Starter
jon1882's Avatar
about 35 miles an hour but i was told such a short distance would not hurt it, so i did not disconnect the drive train. and yes the rear tires were rolling.
jon1882 is offline
post #5 of 9 Old 03-15-2013, 05:41 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Not safe in neutral at all, without the truck running it isn't pumping fluid where it needs, gets hotter faster, and you mite try dropping the pan and see what falls out, err I mean looks like, could be a bad valve body now or worse, but I hope someone more knowledgeable on the e4od can chime in here
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 9 Old 03-15-2013, 06:00 PM
dazed01's Avatar
Did you add transmission fluid to the correct level?
Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars.
dazed01 is offline
post #7 of 9 Old 03-15-2013, 06:46 PM
Powerstroke Techie
forddieseldoctor's Avatar
If you pumped most or all of the fluid out while driving more than likely your trans is toast. What happens when you pop a line off is you loose the rear lube circuit and pretty much start melting stuff together.
You didn't dick anything up towing it a couple of miles. I've flat towed stuff 10 miles without it running, as long as you go slow enough (25-35 mph) you can generally get away with up to 10 miles and be just fine.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #8 of 9 Old 03-16-2013, 06:04 PM Thread Starter
jon1882's Avatar
well that sucks oh well guess i'll get it rebuilt or whatever anybody got any idea on what that'll run?
jon1882 is offline
post #9 of 9 Old 03-16-2013, 06:46 PM
creekfreak's Avatar
You can prob get a basic rebuild for around 2 grand depending on what you cooked. Pony up 5 large for a BTS and don't ever worry about it again.
Chad
95 ECLB 4x4
Rebuilt e4od
320k kilometers (Canadian truck)
BHAF DIY mod
Cat/muffler delete
Diamond Eye 3" downpipe
Western pro-plus plow on an ultra mount
Running Goodyear Dura-tracks on stock rims.
If you're wondering about the handle... Creekfreak... I paddle hard, steep, whitewater. It's been my online handle for about 15 years.
creekfreak is offline
Tags
7.3 diesel , trans , transmission
