Fifth wheel towing - Ford Powerstroke Diesel Forum
post #1 of 42 Old 03-14-2013, 09:44 PM Thread Starter
toad's Avatar
Quoted: 16 Post(s)
Fifth wheel towing
So I have to drive to Washington the first of April and pick up this trailer. It is a 39 foot Teton rv. Dual axle. Weighs 13,500 lbs or so I am told. I will be hauling this trailer about 650 miles to southern Idaho.
My truck is a 96 F250 crew cab. Mods include air bags, heavy duty trans, large trans cooler, mag tech trans pan, and gauges. Just installed a 16k slider 5th wheel.
Is my truck capable of towing this much weight? Is there anything that I need to be aware of? I pull 10k all the time on the bumper and it does great just never towed this heavy.
toad is offline
post #2 of 42 Old 03-14-2013, 10:12 PM
dieselmatt's Avatar
Quoted: 4 Post(s)
Basically this is just a bump up for ya...
That said, I've heard that towing a 5er is a lot easier than a bumper pull. As for the weight, I'm sure other OBS owners can chime in on that. I know this doesn't help at all, but like I said, its basically a bump for ya!
dieselmatt is offline
post #3 of 42 Old 03-14-2013, 10:18 PM
dieselmatt's Avatar
Quoted: 4 Post(s)
Found THIS. Hope it helps!
post #4 of 42 Old 03-14-2013, 10:20 PM
JSchuricht's Avatar
That seems really light for a 39' trailer but 13,500 lbs isn't all that bad. As long as you have the 4.10 gear option vs the 3.55 you'll be fine. You won't be passing anyone but you can pull it fine.
JSchuricht is offline
post #5 of 42 Old 03-14-2013, 11:08 PM
creekfreak's Avatar
Given the 650mile mark you stated, you'll have at least one big pass to pull over the Blue mountains (watch it coming down the east side too, it can get hairy). Not to mention all those big grades over the snake river country.
Take your time.
Chad
95 ECLB 4x4
Rebuilt e4od
320k kilometers (Canadian truck)
BHAF DIY mod
Cat/muffler delete
Diamond Eye 3" downpipe
Western pro-plus plow on an ultra mount
Running Goodyear Dura-tracks on stock rims.
If you're wondering about the handle... Creekfreak... I paddle hard, steep, whitewater. It's been my online handle for about 15 years.
creekfreak is offline
post #6 of 42 Old 03-15-2013, 12:58 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
towing/moving the weight is fine. it's gunna be stopping that i would be worried about. check to make sure your brakes are good. and downshift
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is online now
post #7 of 42 Old 03-15-2013, 08:58 PM Thread Starter
toad's Avatar
Quoted: 16 Post(s)
Yea truck is 4.10 gears. I have never driven the Blues before this will be a first. I know there is some decent grades between Boise and Twin Falls. Not terribly worried about stopping it. Having a good controller makes all the difference. Tomorrow I will be installing my 6.0 cooling fan. Service it next weekend and I will be ready to go.
toad is offline
post #8 of 42 Old 03-15-2013, 09:07 PM
creekfreak's Avatar
It's been a few years since I've driven over the blues, but IIRC the climb up from the west is really really long and the drop down to Boise is pretty steep with some pretty good turns to keep things dicy lol. Where are you picking it up if you don't mind me asking. I know quite a few back roads out there that might not save you time but could save you a transmission....keep your TC locked as much as you can.
Chad
95 ECLB 4x4
Rebuilt e4od
BHAF DIY mod
Cat/muffler delete
post #9 of 42 Old 03-15-2013, 09:39 PM Thread Starter
toad's Avatar
Quoted: 16 Post(s)
Kelso WA. How do you know when your TC is locked up?
toad is offline
post #10 of 42 Old 03-15-2013, 10:22 PM
creekfreak's Avatar
If you're cruising at highway speed and you lightly tap the brake peddle while maintaining your throttle position, your tack will jump up a couple hundred rpm's when your TC is locked. Do that a couple times between now and then and you'll get a feel for it.
And from kelso, forget the back roads like I mentioned earlier. If you can head east in the morning, you'll at least get a tailwind through the gorge. It can get really windy out there especially this time of year.
The drive is amazing. It's hard to keep your eyes on the road!
Chad
95 ECLB 4x4
Rebuilt e4od
BHAF DIY mod
Cat/muffler delete
