10k mod to my truck? - Ford Powerstroke Diesel Forum
Old 01-17-2008, 05:23 PM
will the 10k resistor mod even work on my direct injected 94 PSD? i picked up the resistor but i just need to know where the fuel pressure sensor is so i can do it. i looked in my manual and couldnt find it. does it even have one?
thanks
jeff
Old 01-17-2008, 05:30 PM
duct tape & zip ties
thanks
jeff
If I remember correctly on the 94's the injectors are outside of the valve cover. The 94's have a fuel injector pump. If my memory is correct then no the 10k mod will not work on your truck.
Old 01-17-2008, 05:32 PM
no. its the later 94-98 powerstroke. youre thinking of the mechanical injection. mine is electric just like the 95+
Old 01-17-2008, 11:09 PM
got it!!! i read somewhere that it was on the passenger side behind the alt. and it's night time. its actually the drivers side under the cover. i did the 10K mod and it was the best $3.24 ive ever spent! it made a huge difference! (i have a stock motor with a straight pipe dump before the axle)
