adding additional batteries - help with wiring - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-14-2013, 11:24 AM Thread Starter
Boise Outlaw's Avatar
I'd like to add 2 additional batteries to my setup. I would like all 4 to be charged using the single high-output alternator, but I would like the additional batteries to remain separate from the starting system when in use to ensure that if they become fully discharged I will still be able to start up the truck. Is there a simple way to do this or am i forced to run all 4 batteries in parallel?
97 OBS F250 Ext Cab Long Bed 4x4 ZF Swapped
VO conversion, TS 6 Position Chip, E Fuel, 6637 Filter, EBPV delete + PCV Reroute, Diamond Eyes 3" Downpipe
Boise Outlaw is offline
post #2 of 7 Old 03-14-2013, 12:36 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
They sell a thing that seperates them I can't recall what is is tho, car guys use it for stereo's tho to run dual batts
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 7 Old 03-14-2013, 01:00 PM Thread Starter
i did some further research and it looks like i just need a battery isolator like how RVs are set up. I wasnt sure if they were using separate alternators to charge those batteries or not. I've got an espar, winch, and inverter I'm running that i dont want draining my starter batteries when i'm out in the sticks.
post #4 of 7 Old 03-14-2013, 01:02 PM
Sam Burton's Avatar
yeah all you need is a heavy duty relay so 2 batteries are disconnected when the key is off.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #5 of 7 Old 03-16-2013, 03:45 PM
Undead Member
gaspipe's Avatar
Quoted: 6 Post(s)
With that nice cap on the bed, you could also add a few solar panels to the roof and a charge controller......
~Bruce~
'95 F250 4x4 ECLB 296k - ZF5, Southbend, 4.10, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 4" exhaust, BFAF, 6.0 fan, 140v IDM, Autometer, MagHytec diff cover, HD ft springs, 16x8 alloys
'95 F-Superduty 4x2 CM 12' Flatbed 47k - E4OD, 5.13, Banks intercooler, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 3/5" side dump exhaust, BFAF, PHP tunes, 6.0 fan, 140v IDM, TruCool, MagHytec diff/pan, Dieselsite exl trans filter, Autometer, 180w LED bar
gaspipe is offline
post #6 of 7 Old 03-16-2013, 10:00 PM
JSchuricht's Avatar
You have a few options depending on budget.
1) Parallel the batteries and use a manual disconnect switch for the auxiliaries.
2) Parallel the batteries with a relay to disconnect the auxiliaries. Power the relay from the ACC circuit or a switch. Down side is if the dead batteries connect when your trying to start, the additional load may keep you from starting.
3) Parallel the batteries with a battery isolator. This will only connect the aux batteries for charging and keep them isolated when the truck is off.
4) Parallel the batteries with a relay controlled by a battery isolator controller. All the functions of 3 with the added benefit of being able to automatically jump start yourself if the primary batteries die and the aux is charged.
#4 is what I use along with a 500a Tyco relay designed for a electric car and some 4/0 cable to connect everything together.
JSchuricht is offline
post #7 of 7 Old 03-16-2013, 10:33 PM
Maverick1701's Avatar
Send a message via AIM to Maverick1701
could you use a setup like boats use? sometimes they have multiple batteries and charging banks.
ChrisChris
2003 Kawasaki KLR650
1997 Ford Expedition 4x4
1967 Kaiser Jeep M35A2 6x6
2016 Silverado 4x4 Crew-Cab LS/Police
Maverick1701 is offline
