Steering wheel problem - Ford Powerstroke Diesel Forum
post #1 of 20 Old 01-16-2008, 05:59 PM Thread Starter
OK guys...I need some help here.
Driving home from work yesterday and my steering wheel feels like it is going to fall off. Well....not fall off but I can wobble it from the 12 and 6 position about 1/4" to 1/2" of an inch. Is there some kind of bushing or bearing under the steering wheel? And if there is...how do you get the steering wheel off?
Thanks Guys,
Brad
BradJ is offline
post #2 of 20 Old 01-16-2008, 06:00 PM
strokerboy73's Avatar
What year of truck??? Sounds like the bearings are going out or gone out.. My dad just had to fix a bunch of stuff in his steering collum on his 95. Its was about $350.
-2003 7.3L Powerstr
ke, 4x4, Crew Cab, 170K Miles
"The Last Of A Dying Breed."
-Banks 6 Gun -Straight Piped
-Zoodad Mod -DIY Intake -CCV Mod
-B&W Turnover Ball -Prodigy Brake Contoller
Future Mods:
-4 into 5 in. Turbo Back Exhaust. 6 in. Tip
-Custom Front Bumper
strokerboy73 is offline
post #3 of 20 Old 01-16-2008, 06:21 PM Thread Starter
Its a 1996 F250
Did he get to everything by taking the steering wheel off? If he did..did he just use a standard 2 jaw puller?
Thanks
Brad
BradJ is offline
post #4 of 20 Old 01-16-2008, 06:44 PM
Originally Posted by BradJ View Post
Its a 1996 F250
Thanks
Brad
He had to pull the whole thing because there are bearings on both ends. I would pull the steering wheel off first. he didnt have to, but his was so worn out he just hit it off with a hammer. . its not to bad to do.
-2003 7.3L Powerstr
Future Mods:
post #5 of 20 Old 01-16-2008, 06:49 PM
steering wheel problems
Are you talking about steering play?If so its in the supension not the cab.I replaced the tie rod ends and adjusted the steering box a 1/4 turn.If your steering wheel can be lifted up and down,then you pull the steering wheel and tighten everything up.
if its tilt you tighten up differently,but it self explainatory.I rented a steering wheel tool from auto zone for the chevy I don't know about the ford.Ask auto zone,they have the tools if you need it.Its simple thought,just take you time.
greenie is offline
post #6 of 20 Old 01-16-2008, 11:29 PM
adfields's Avatar
Its a 1996 F250
Thanks
Brad
No, don't use a jaw puller! Use a steering wheel puller. Turn the wheel straight up and reach through with both hands to the back of the plastic cover, or air bag cover if it's got an air bag. Pull upward and to you and the cover will snap loose, some come right off some fight.
Now you remove the big nut and install the puller, it bolts in the 2 small threaded holes and pushes on the big bolt or steering shaft. From there you should be able to pick your way down to the bearing and swap it out.
ANDY
My baby is a one of a kind.
1977 I bought a new 76 F150 club cab.
Sitting on a 84 F350 6.9 4X4 chassis
With all the drive train and goodies from a 95 4X4 4door PSD.
Nothing stock left on her and not a nut, bolt, hose, or wire on there that I didn't put where it is.
The Wifes Ride:
2002 Excursion Limited 7.3 PSD
Themo King/Mikuni coolant heaters on both to keep things toasty without idling.
adfields is offline
post #7 of 20 Old 01-16-2008, 11:32 PM
adfields's Avatar
Ford takes the same tool, and it's a must if you dont want more damage.
ANDY
The Wifes Ride:
adfields is offline
post #8 of 20 Old 01-17-2008, 02:42 AM Thread Starter
Yea..I figured that you had to use a puller. But on my truck's steering wheel..there is no place to install the puller..ie. no threaded bolt holes. Thats what my concern is. I'll try to take a picture and post it this evening.
Thanks,
Brad
BradJ is offline
post #9 of 20 Old 01-17-2008, 06:06 PM
i had the same problem with mine. there was play in the steering wheel, i could move the steering wheel up and down, talked to my mechanic and he said your better off just finding a used steering column and replacing the old one because it would be cheaper then having to go though and take the column apart. so i shopped around a little and found a steering column for 250 and it took me about 3 hours to take the old one out and put the new one in. havent had any problems and works great!
1997 F350 xlt Power stroke diesel
Regular Cab Long Bed
TS performance chip
tougas is offline
post #10 of 20 Old 01-17-2008, 07:52 PM
Yea. if you can find one. You have a 97, but my dad has a 95. So it was harder to find since that was the only year out 95,96, & 97 that didnt have an airbag.
-2003 7.3L Powerstr
Future Mods:
