Coolant gauge indication - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-13-2013, 01:23 PM Thread Starter
http://img593.imageshack.us/img593/8642/imageqri.jpg
Been a little concerned about my coolant gauge for a while, never stays in the middle of the C and H, infact, it's never been like that until I climb a small hill then it shoots up rapidly. Not too sure if my TStat is stuck open or I'm just being totally paranoid!?
Anyone got any suggestions?
Struggling to post pictures up via iPhone.
Many thanks in advance
Rob73 is offline
post #2 of 5 Old 03-13-2013, 02:06 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
How high does it shoot up? Mine stays just a little higher than that but not much, got it mid level once towing up hill a good load
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 5 Old 03-13-2013, 02:16 PM Thread Starter
Yeah, same as mine. Went between the M and L when towing uphill then for some reason went into "lag mode" (or so it seemed). I completely lost power, didn't stall but just didn't have anything there. Initial thoughts was some sort of temp overload which wouldn't make my revs go over a certain limit to try and drive down the temperature?
Rob73 is offline
post #4 of 5 Old 03-13-2013, 06:37 PM
Question
This "lag mod" is interesting, and seems something similar with my truck,: ...Initial thoughts was some sort of temp overload which wouldn't make my revs go over a certain limit to try and drive down the temperature?... and EGTs, so Id like to hear comments about this. Or maybe is something wrong with my auto tranny: solenoid?
CELAYORK is offline
post #5 of 5 Old 03-16-2013, 01:38 PM Thread Starter
Running too cool
Hey Guys,
Just wanted to update this to those that commented. So my temp guage was running on the first line of the normal (see pictures above). I researched it a little more and found the link above.
I decided to change out the TStat for new. For the cost of $18 decided the job was worth doing just to prove a point.
My guage now reads between the N and the O part of "normal". So my old TStat was indeed stuck open constantly cooling my engine (oil) and never getting upto the so called perfect 203F these trucks like to run at.
My old TStat was made in Germany so guessing it wasn't the stock one but a cheap one from eBay. There are certain things worth saving money on but when it comes to something as important as the thermostat I would rather spend the extra few dollars!
I hope this post helps others out in the future.
Rob73 is offline
