zf5 tramission fitment question - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-13-2013, 12:10 PM Thread Starter
Hey guys, Im almost done rebuilding my zf5 but long story short I think I need a new case.
There is a tranmission for sale locally and its a 5 speed that was hooked to an IDI, I know this is probably a s42, but is the front case still the same(bell housing side).
Ive read the syncros are different, but I'm not exactly sure all of the differences. Will the bellhousing off of an idi zf5 bolt to a powerstroke? will the shafts out of a s47 fit in? I have a fully rebuild main shaft and counter shaft, its just my front case is bad.
Any suggestions or help would be awesome
Thanks!
1997 F250 7.3 5 speed, 3.55s, D60, 4" Diamond Eye Exhaust, Napa Intake Filter, E-Fuel, 35" bfg mt's, stage 2 rosewoods/tuning, Gauges
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
--Henry Ford
csdwarf11 is offline
post #2 of 10 Old 03-13-2013, 12:34 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The case will work as in bolting up, these trans a diesel only, as in idi and psd are same, now 6.0+ won't work tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 10 Old 03-13-2013, 01:29 PM Thread Starter
Awesome, so it will bolt up. now I'm just curious if the internals are the same. Ill look around for diagrams.
Thanks again.
--Henry Ford
post #4 of 10 Old 03-13-2013, 02:23 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
The 47 has internal gussets, so I do not know
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 10 Old 03-13-2013, 03:07 PM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 4 Post(s)
Feedback Score: 3 reviews
Same bell housing, it will bolt up and should work fine for you. You probably already know that it is the weaker of the 2 and prone to the case cracking where it bolts to the tcase/cross member. I have also heard of cracks at the bell housing. SO if you buy make sure you inspect really good.
What is the story of your case. We had an IDI farm truck one time that ended up with a crack in the bell housing that was about 7" long. Had it TIG welded and it worked fine for us for a few years. We sold the truck to a neighbor farmer and he is still rocking it today. Our luck might not be your luck but it might be worth a try??
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #6 of 10 Old 03-13-2013, 04:50 PM
The idi bolt patern is the same at a big block ford also
Turbo_pace is offline
post #7 of 10 Old 03-13-2013, 04:52 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
But a 460 trans won't bolt up to a psd
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 10 Old 03-13-2013, 04:56 PM
Quoted: 4 Post(s)
NO, it is Not the same. Similar but Not the same
post #9 of 10 Old 03-13-2013, 06:22 PM Thread Starter
Well, I appricate all the help, and Ill explain why I went from tranmission rebuild to needing a new tranmission.
Well, The bellhousing was all cracked up from DMF obviously coming apart on a previous owner. I don't like putting broken sh!t together like that, but I figured I would rebuild the transmission because I had nothing else to work with and needed to get my truck on the road ASAP.
Fast forward past rebuilding the main shaft (went great, I have a fully rebuild main shaft!) and I am inspecting the cases before installing the bearing races into them. I notice a small crack around the input shaft area, under the throwout bearing assembly. I tig welded it the best I could. Another long story short I put the bearing races is, and the crack was bigger, hitting the races in made everything worse. I welded that up in a last attempt to make this all work.
Now LAST step, transmission is going back together, I'm carfully taping the input seal in, and the entire casting around the input shaft the busts out( NOT WHERE I WELDED IT, a whole new crack), I was hardly hitting it...it obviously had no strength what so ever. So after throwing everything on the bench and within reach across the shop I calmed down and inspected everything. It's not practical to weld it up, this case is such a peice of sh!t its not worth anymore hours.
So I'm sitting there with a fully rebuild main shaft, a rebuild small case half (all gears and shafts installed into it, ready to drop the bellhousing half onto) and my LARGE case half is FUBAR.
I'm seriously pissed and don't what what to do next, rebuilding a zf5 is honestly pretty easy, but its hard to do anything when the case is falling apart faster then you can fix it.
Any leads on case halfs, or cheap remans, or ideas Please....anything :'(
Thanks for everything guys, im just out of ideas at this point.
--Henry Ford
post #10 of 10 Old 03-13-2013, 06:28 PM Thread Starter
So really all I need is a front case half(bellhousing) for a zf-47. I can imagine they are hard to find considering ford basically designed them to get blown to bits with the flywheel being in there.
Another option (less ideal) would be buy another tranmission. I have to look at costs through, I don't have all the money in the world..anywhere cheap quality remans? I might have to take that route if I can't find a case.
Another option (less ideal) buy this zf5-42? off of a 93 IDI, from what you all say it will fit. I will be buying an unknown tranmission that could be just as bad as what I had before. If I cant use the internals from my s-47 IN the s-42 then I would be back to the starting line, rebuilding a zf5.
Any help would be awesome, I need to for sure still frusterated considering all the time I had into the junk case, just for it to fall apart on me again.
NOTE* DO NOT EVER CONSIDER continuing to run your DMF, I see people asking all the time. SECOND do not half *** repair it, and sell the truck to someone without telling them, acting like it never happened.
--Henry Ford
