Another downpipe thread! - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-13-2013, 09:58 AM Thread Starter
Just need to know what the size of the stock downpipe is?
Noticed that Summit racing sells 3" and 4" 2 piece DP's. I got the stock "cobra" head right now and ready to hack the thing out and replace.
Sorry if this has been posted up many times but can't seem to search on here with my iPhone.
Many thanks in advance!
Rob73 is offline
post #2 of 10 Old 03-13-2013, 10:08 AM
Quoted: 47 Post(s)
Unless you have a body lift, only a 3"-er will fit, and even that will take a minor mod to the cab.
madpogue is offline
post #3 of 10 Old 03-13-2013, 10:11 AM Thread Starter
Many thanks, that's just a straight swap and 3" at both flanges?
Rob73 is offline
post #4 of 10 Old 03-13-2013, 10:12 AM
superduty4x4's Avatar
On my exhaust kit I'm pretty sure the down pipe is 3" until the flange where the cat would be, then the cat delete pipe goes to 4". I mean... if one was to run a cat delete pipe of course.
Making a 4" down pipe fit requires extensive firewall modifications. It's not worth it.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #5 of 10 Old 03-13-2013, 10:16 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Assuming we are talking OBS truck, the outlet flange on the turbo is only 3". The 4" is probably for an SD 7.3 which has a 4" outlet.
The swap is not difficult... You have to either cut the pinch weld or bend it out of the way. Cutting the stock DP is the easiest way i have found to get them out.
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #6 of 10 Old 03-13-2013, 11:19 AM Thread Starter
Will be ordering this today, thanks for everyone's input. I got a decent 6' piece of 2" pipe ready to bend the firewall already.
Rob73 is offline
post #7 of 10 Old 03-13-2013, 12:01 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I used an air hammer cut the pinch weld on both sides I needed to fit the dp, and bent it down, good luck with yours
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 10 Old 03-13-2013, 02:53 PM
I used a duck bill on a porta power to push the fire wall back. Makes life soooo easy.
post #9 of 10 Old 03-13-2013, 06:18 PM
Wink
X2 on that, and you dont need to cut anything and no issues with future corrosion in the cuts.
CELAYORK is offline
post #10 of 10 Old 03-13-2013, 06:23 PM
Lightbulb
Are you going to use your catalytic converter or your are going to dich it and install a 4" pipe?. FYI there are DP that goes from 3" to 4" in two pieces.
CELAYORK is offline
