HOW BIG OF TIRES - Ford Powerstroke Diesel Forum
Old 01-14-2008, 05:17 PM
Send a message via MSN to strokerman12
HOW BIG OF TIRES
Ok so i bought a 1996 powerstroke f-350 crew cab and when i bought it im sure it is higher than stock because she put "camper springs" on it and i dont know how much higher it would make it so im wondering if i could fit 35's under it with now rubbing???? by the way i do offroad a lil bit. So if you could give me some help it would be appriciated.
Old 01-14-2008, 05:30 PM
Send a message via MSN to Canadian Stroker
I'd say a good 4" of lift is needed to clear 35s comfortably, especially if you want to go wheeling.
Old 01-15-2008, 12:51 PM
BIG TRUCK, SMALL DRIVER
33's should fit no problems. It's been a while since I thought about bigger tires, I can't remember what would fit. I'm sure someone has tried 35's.
Old 01-16-2008, 04:30 PM
4" with 35's, they say they will clear.
Old 01-16-2008, 04:43 PM
International Threat
Leveling kit and trim the front bumper... you'll probably still rub at full lock off camber...
