95 block - Ford Powerstroke Diesel Forum
Old 01-13-2008, 07:12 PM
95 block
is the 95 block the same as 96 and 97? will parts interchange? i know that in 96 they updated the HPOP, high pressure resevoir with a stand pipe, and different pistons my main concern is will a new HPOP resevoir fit on a 95 block?
Old 01-13-2008, 07:30 PM
lukecline
Guest
Posts: n/a
The 95 blocks had a less webbing in the lifter area, my engine builder said it probably wouldnt make a difference strength wise. FWIW i run a 95 block with my highly built engine. You are correct about the front cover they changed it in 96, but it will work w/o problems on the early model blocks.
Old 01-13-2008, 07:51 PM
cool
cool thanks
