95' OBDII reflash - Ford Powerstroke Diesel Forum
Old 01-13-2008, 09:57 AM
95' OBDII reflash
I have a 95' F350. I tried to hook up my actron scanner the the OBDII port. The scanner turned on and tried to connect, but it didn't work. I have power at the port. I read that some of the early 95's aren't fully OBDII compliant, and my truck was made in Dec of 94'. I think that my truck needs to be reflashed. Does anyone know how to do this? How much is it going to cost me? Can I get a flash from a 97' model truck? I thought I read that the 97' had a better tune than a 95'.
Old 01-14-2008, 08:07 PM
What is the pcm calibration code for the OBS with an automatic?
Old 01-14-2008, 10:02 PM
I would also like to know, so hear is a bump.
Old 01-15-2008, 03:50 AM
The latest OBS auto PCM code is TDE1. I've heard some have been able to go to the stealership and for about 50 bucks have their truck flashed. No personal experience though.
Old 01-15-2008, 07:13 PM
I went to my local 'big' Ford dealership, and hey told me that the don't think that can reflash a 95'. They said if they could it would be $90.00, and if they couldn't it would be $45.00. I don't like the sound of this. Does any know of a better way? Has anyone had their PCM reflashed by DP-Tuner?
Old 01-16-2008, 04:03 AM
DP is a great way to go. Only downside is the downtime while you send your PCM to him and have it shipped back.
Old 01-16-2008, 04:45 AM
There was an OASIS or TSB on this for '94 models and they had to be reflashed to a '96 I believe. Do your research and the dealership may do it for FREEEEE. I just recently had mine replaced and it only cost $224 for the whole thing (part not labor) at the truck shop. Total bill around $800.
You might try looking around your local yards and just swapping it out. Then again, I might be wrong.
