5 speed to 6 speed - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-08-2013, 05:05 PM Thread Starter
Arrow 5 speed to 6 speed
5 speed is getting ready to come apart in my truck thinking about changing to a 6 speed if I can find one is there any major changing I'll have to do to make it work and will my t-case change over and bolt to it
duckstroker is offline
post #2 of 10 Old 03-08-2013, 05:25 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Doubt the t case would, obs uses a bw, sd has an np, your gonna have to modify the trans hump, and a trans cross member too
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 10 Old 03-08-2013, 09:21 PM Thread Starter
Alright thinks for the help I checked the ratios and not much difference in them other than a lower first gear
post #4 of 10 Old 03-08-2013, 11:45 PM
JSchuricht's Avatar
The transfer case in the super duty had a different input for auto and manual trucks. The OBS used the same input on auto and manual that was used on the SD autos.
JSchuricht is offline
post #5 of 10 Old 03-09-2013, 01:37 PM
the baconator
terryknight's Avatar
Quoted: 150 Post(s)
owning both it's not worth it. zf6 also has a trans cooler and you will need different driveshafts i believe
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #6 of 10 Old 03-09-2013, 02:30 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Shorten rear shaft, lengthen front shaft, ''massage'' the trans tunnel, add a trans cooler and lines, make a custom trans cross member, swap T-case.... if u already have a 5 speed, just rebuild it, or replace it with a 5 speed
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #7 of 10 Old 03-09-2013, 09:32 PM Thread Starter
Yea truck is already a 5 speed just doin a little think since overdrive is same ratio it really ain't worth it I got 4.10 so I was wanting lil higher overdrive and lower first put after I checked them I and saw them the same I purdy much changed my mind. Thanks for the help guys now I know I just gonna rebulid my zf5
post #8 of 10 Old 03-10-2013, 03:52 AM
ol_Blue97's Avatar
I thought the ZF6 had a higher 6th gear too... but not much. Ive seen so much contradicting info on the gear ratio of the zf6 its crazy
FRANK THE TANK
post #9 of 10 Old 03-11-2013, 05:52 PM Thread Starter
From what I saw on one page overdrive is got same ratio on both but that was just one I saw chart
post #10 of 10 Old 03-12-2013, 12:25 AM
Quoted: 54 Post(s)
It's pretty close, something like .77 on the ZF5 and .72 on the ZF6. IIRC, the ZF6 also requires a pump and a cooler.
madpogue is offline
