high output alternator replacement?? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 03-08-2013, 10:48 AM Thread Starter
Woodturner Nate's Avatar
Quoted: 2 Post(s)
Does the super duty alternator fit the OBS trucks?? I'm trying to find an affordable alternative to the $400 "mean green" alternator. I don't need a 270 or 300 amp, but the stock one isn't enough at idle to keep a couple sets of auxiliary lights, compressor, etc, from dimming the headlights. Before anyone asks, yes my batteries are new! The SD 200-amp replacement alternators can be had for about $150 + shipping.
2007 F350 King Ranch CCLB 4x4
WVO conversion in planning
RIP 1996 F250 eclb, 4x4, 7.3L PS
Viair 444C/6g air tank on frame, Hadley air horn, Hella auxiliary reverse light, DIY WVO conversion; Efuel, dual FuelLab FPR's, 90g RDS tank, aluminum tube-in-heater hose, hotfox heated fuel pickup, copper coil-wrapped filter, 40-plate FPHE, auxiliary coolant pump, 2000lb winch-crane bolted to the frame. Ranch hand front bumper. Big winch.
Woodturner Nate is offline
post #2 of 17 Old 03-10-2013, 07:56 PM Thread Starter
Quoted: 2 Post(s)
Seriously? Nobody has tried to see if the SD alternator will fit on an OBS truck? I would've thought that with the price difference between the OBS and SD alternators, someone would've tried by now. I just don't know anyone with a 7.3 in their SD. I know plenty of 6.0 owners, but no one whose parts I can size up. Somebody has to have tried this.
post #3 of 17 Old 03-11-2013, 12:45 AM
birdco85's Avatar
Re: high output alternator replacement??
Wondering as well, mine just pooped the bed...
1995
F350 PSD, 4x4, CCLB, Auto, 236,xxx, Tymar, 4" Diamond Eye, PHP FU2 chip, T-500, Rosewood Stage 2.5's, DIY E-fuel, Intercooler, Gauge's (Pyro, Boost, Trans), CCV Mod, Explorer OHC....way more to come.
birdco85 is offline
post #4 of 17 Old 03-11-2013, 02:45 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 4 Post(s)
Feedback Score: 3 reviews
Try Napa, they offer some high output alts... A lot of guys go with the ambulance alt.
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #5 of 17 Old 03-11-2013, 06:40 AM
birdco85's Avatar
The ambulance one is 240, I'm like the op, just want want a little more. our alternators are the 3g series, the super duty's are 6g. Just wondering if they interchange.
1995
birdco85 is offline
post #6 of 17 Old 03-11-2013, 07:08 AM
Hillbilly Deluxe
Quoted: 4 Post(s)
Ambulance was just a reference... Napa offers higher amp alts for obs trucks...
Seth
Stroked_NY_023
post #7 of 17 Old 03-12-2013, 07:41 AM Thread Starter
Quoted: 2 Post(s)
I'll have to check Napa when I can. All the ones I've seen online have been either close to or well over $300. You can find a SD "high output" for a lot less. I don't need 240 amps, but I'll post an update when I find out one way or another....
post #8 of 17 Old 03-12-2013, 08:19 AM
Hillbilly Deluxe
Quoted: 4 Post(s)
IIRC SD wont work, totally differnt mount, different side of motor.
Sent from AutoGuide.com App
Seth
Stroked_NY_023
post #9 of 17 Old 03-13-2013, 07:38 AM Thread Starter
Quoted: 2 Post(s)
That's what I needed to know. Thanks
post #10 of 17 Old 03-14-2013, 07:11 AM
Wink
This not respond your question, but maybe helps you:
DB Electrical - 220 Amp
CELAYORK is offline
