What axle is this - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-07-2013, 10:26 AM Thread Starter
What axle is this
What axle is this
nvrstsfd23 is offline
post #2 of 9 Old 03-07-2013, 10:27 AM
That is the "front" axle.
2006 built 05/05 XLT CC DRW PSD. Captain chairs, sunroof, polished aluminum wheels, 6speed, manual 4x4. 285K miles with 130K problem free miles on new engine.
RatherBNtheWoods is offline
post #3 of 9 Old 03-07-2013, 11:05 AM
jake-96-7.3's Avatar
Send a message via Yahoo to jake-96-7.3
twin traction beam dana 50...came stock in obs f250s there should be a 50 cast into the housing
1996 F250 ext cab long bed
AFE stage 2 intake
Ts6 chip Tw tunes
Isspro EV2 Gauges
Dacco billet cover triple clutch HD Torque converter
3in down pipe
5in straight pipe
6 in tip,
true cool 40,000btu trans cooler
203 thermostat
Firestone ride rite air bags in rear
tinted head lights turn signals markers sd tinted fogs
Kenwood head unit
full JL audio sound
jake-96-7.3 is offline
post #4 of 9 Old 03-07-2013, 01:00 PM
jjones96's Avatar
↑ yep d 50
The STROKE
1996 F-250 Powerstroke
7.3 DI T444E.
TS 6 Postion chip
Gloshift max tow gauges
3 inch dp to 5 inch exhaust
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
Redneck weight reduction
The work truck
2012 Ford F-350 DRW 6.7 Powerstroke
C&M Flatbed
100 gallon slip tank
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #5 of 9 Old 03-07-2013, 01:25 PM Thread Starter
There the one that no one wants so I should look for a Dana 60 for a swap
I didn't know they had leaf springs I thought it was ifs
post #6 of 9 Old 03-07-2013, 01:48 PM
buckels's Avatar
Send a message via AIM to buckels Send a message via MSN to buckels Send a message via Yahoo to buckels
It was Fords attempt at an IFS IIRC
Drew
99 SD 6SPD manual
AFE Intake
Diamond Eye 4" turbo back exhaust
Wicked Wheel Gen2
PHP Hydra tunes by Bill
If you live in WA or OR check out these links.
buckels is offline
post #7 of 9 Old 03-07-2013, 02:39 PM
JSchuricht's Avatar
Originally Posted by buckles24 View Post
It was Fords failed attempt at an IFS IIRC
Fixed it for you.
It's similar to the d44 ttb you would find on 150's and bronco's but uses leaf springs. Might have been a decent option if Ford went with coils but they used leaf springs and due to the pivot of the axle from the cross member, they had to use extra heavy leafs to withstand the twisting effect. The end result is springs that don't give and have nearly no travel. Defiantly stay clear of that axle and try to find yourself a D60.
JSchuricht is offline
post #8 of 9 Old 03-07-2013, 03:23 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It is ifs, just on leafs, rides like a tank, ditch it and go d60
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 9 Old 03-07-2013, 03:48 PM
buckels's Avatar
Re: What axle is this
Agreed it rides like chit!
Sent from AutoGuide.com App
Drew
99 SD 6SPD manual
AFE Intake
Wicked Wheel Gen2
buckels is offline
