Degas bottle problem. HELP - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-06-2013, 06:44 PM Thread Starter
My coolant is not sucking back into,my radiator after driving it. Coolant in degas bottle is almost to the top, so idk if i should keep driving it as is. I have no clue what could be wrong. I was told a coolant leak somewhere along the line, i had a radiator leak and put stop leak in it, which i know now was a bad idea. I am new at diesels, so had no idea. There is ome greenish looking stuff in the valley, i was thinking fuel, but idk? Any help would be appreciated.
Tyler
_95stroke is offline
post #2 of 13 Old 03-07-2013, 07:23 AM
jjones96's Avatar
Dip ur fingers in the "greenish" looking stuff and smell it if it smells like coolant it could be a bad heater hose.if its diesel it might be time to reseal ur fuel bowl and change the three little hoses off the fuel pump. Or possibly be fuel pump leaking
The STROKE
1996 F-250 Powerstroke
7.3 DI T444E.
TS 6 Postion chip
Gloshift max tow gauges
3 inch dp to 5 inch exhaust
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
Redneck weight reduction
The work truck
2012 Ford F-350 DRW 6.7 Powerstroke
C&M Flatbed
100 gallon slip tank
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #3 of 13 Old 03-07-2013, 07:46 AM Thread Starter
It is fuel, i changed my fuel filter not too long ago and it leaked cause i didnt get it tight enough first time. But any idea as to why it wouldnt be sucking back into the radiator? Thats really bugging me, nothing leaks to my knowledge now.
post #4 of 13 Old 03-07-2013, 09:53 AM
Quoted: 50 Post(s)
Maybe the stop leak stuff clogged up the line from the reservoir into the radiator?
madpogue is online now
post #5 of 13 Old 03-07-2013, 10:37 AM Thread Starter
Could be, but the coolant still flows into the reservoir, just not out of it? Im going to try to replace the radiator cap and see what happens. Could a bad radiator cap cause that?
post #6 of 13 Old 03-07-2013, 11:04 AM
jjones96's Avatar
Not 100 percent sure but i would say it could
The STROKE
7.3 DI T444E.
TS 6 Postion chip
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
The work truck
C&M Flatbed
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #7 of 13 Old 03-07-2013, 11:39 AM Thread Starter
Ok, i will try replacing it and hope it works.
post #8 of 13 Old 03-07-2013, 12:43 PM
Quoted: 50 Post(s)
Are you talking about the cap on the degas bottle? Or do you have a radiator with a cap? If your radiator has a cap, it's the wrong radiator, and it may be why the coolant isn't flowing the way it should.
post #9 of 13 Old 03-07-2013, 12:53 PM Thread Starter
I have a radiator with a cap. The early 94.5s and 95s came with a cap on the radiator. The radiator cap part # is motorcraft rs 90.
post #10 of 13 Old 03-07-2013, 12:58 PM
Quoted: 50 Post(s)
Then it shouldn't have a degas bottle, at least I don't think it should. AFAIK the early trucks with the rads with caps had an old-school non-pressurized overflow bottle instead of the degas res. If that's what you have, and it's filling up but never returning to the radiator, then for sure it's the cap.
