Wont start - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-06-2013, 12:37 PM Thread Starter
Wont start
Manual fuel pump broke.replaced primed nofuel. Not even smoke while cranking.replaced cam sensor.what am I missing?
Chuck75inf is offline
post #2 of 3 Old 03-06-2013, 04:08 PM
Quoted: 53 Post(s)
Originally Posted by Chuck75inf View Post
what am I missing?
A lot of info.
What year truck? Mods? Chip?
"Manual" fuel pump? Hard to believe. Mechanical, maybe?
Are you getting a WTS light? Is the tach moving? Have you tried both fuel tanks? Have you checked for fuel in the bowl?
madpogue is offline
post #3 of 3 Old 03-06-2013, 04:35 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
If you had the fuel bowl out while doing the pump, make sure the Injection Pressure Regulator (IPR) was reconnected. Make sure the fuel bowl wiring harness was reconnected. Make sure the wiring to the IPR is sound (fuel leaks cause the insulation to turn to goo). Cheers!
Patrick Feeley is offline
