Squirells .... - Ford Powerstroke Diesel Forum
post #1 of 16 Old 03-05-2013, 09:42 PM Thread Starter
Squirells ....
Hey all, I am a powerstroke and forum noob, (see my intro post here). I went to start my truck (97 7.3) this morning and I discovered that the glow plugs were not working. I popped open the hood and nearly had a heart attack when a squirrel ran over my arm and out. He had a nice little nest in the drivers side rear corner of the engine compartment. He had also decided that the wires coming out of the firewall would make a good snack. So I haven't had much time to look at the extent of the damage, but there were at least four or five plus wires that were cut. This Saturday I will try to resplice the wires. Any advice on a proper way to do this?
Also any ideas of inventive and preferably slow ways to kill squirrels are welcome.
trappermat is offline
post #2 of 16 Old 03-06-2013, 02:08 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Crimp and heat shrink... my prefered method is a western union splice soldered and covered in heat shrink but i know this may not be able to be done in your case. Google it if u dont know what it is.
If u do a crimp splice, use a quality crimp connector and use a quality crimp tool.
Could also go to a JY and rob a engine harness and replace the whole thing.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 16 Old 03-06-2013, 04:01 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Funny story, if you scatter a couple dryer sheets around I know those keep rats outta there, being as how rats and squirrels are both rodents that mite work, but I agree with frank on solder and heat shrink
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 16 Old 03-11-2013, 04:31 AM Thread Starter
Thanks guys, got the wires spliced back together over the weekend and she's up and running again.
post #5 of 16 Old 03-11-2013, 04:48 AM
Quoted: 3 Post(s)
well now that the wires are good to go, on to the squirells...
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #6 of 16 Old 03-11-2013, 01:22 PM
ol_Blue97's Avatar
Awesome.....i have a bird feeder that is open on 2 sides and the squirrel always entered on one side and exited on the other. So i wraped one side shut with clear plastic wrap (the exiting side) let him come in, opened the window so he would run out in a hurry and BAM! It was funny but have no viedo.
FRANK THE TANK
post #7 of 16 Old 03-11-2013, 02:41 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
That video is hilarious lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 16 Old 03-11-2013, 03:10 PM
Quoted: 60 Post(s)
I've seen youtubes the Saran Wrap trick done on the cat door. Can't help but crack up.
The thing about any unwelcome visitor, if you kill 'em, more will come back. You have to repel 'em. Dryer sheets are good, I've heard. Our problem has been mice. Haven't chewed any wires yet, but found some nests in two of the trucks. Just started using a product called Fresh Cab. All natural, stuff like cedar and balsam fir chips, and some other wood oils, packed in these sorta giant tea-bags. Smells kinda strong but not unpleasant to us humans, but evidently rodents hate it. Seem to be working in all the trucks, plus the basement and the cabin.
madpogue is offline
post #9 of 16 Old 03-12-2013, 04:46 PM Thread Starter
Awesome...
post #10 of 16 Old 03-12-2013, 04:56 PM Thread Starter
I did set a couple of rat traps in the truck, even though they are a little undersized for a gray squirrel. One was set off on Saturday morning so at least I scared the heck out of him. Currently I have the truck parked in a lot near the U of MN campus, so squirrel densities are through the roof. Next week, spring break, I will be driving it home to the farm where the squirrel numbers are not nearly so out of control. Hopefully, the rat traps will work for the time being.
