Fuel Tank swap - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-05-2013, 06:55 PM Thread Starter
Fuel Tank swap
I have read that some people swap Bronco tanks or a Spectra Premium F26E tanks into long bed trucks. Is there another tank that can replace my stock tanks in my Crew Cab short box truck? Pulling a 38' 5th wheel sucks down the fuel. Thanks.
1996 F250 CCSB Centaurus 4x4, ZF5, 4.10 LS
Melling LPOP, Western Plow 56131K GPR, 203* Thermostat, BB Mod
jjohns816 is offline
post #2 of 10 Old 03-05-2013, 08:33 PM
7.3powerstroker's Avatar
Fuel Tank swap
I'm about to replace my fuel tank in the next couple days and I'm trying to figure what tank to go with also
Sent from AutoGuide.com App
Shelby
1995 F350 7.3l
5 speed
240,000km
DIY Intake
3.5"dp to 5" straight pipe
99 Turbo and Spyder
6" Lift
37" BFG KM2's
Harley Davidson Leather buckets
Grant Steering Wheel
Autometer Gauges Pryo,Boost
CB Radio
Custom Bumper(built it myself)
Clear Headlights (black background)
Black Grille and Headlight Trim
Soon to come
Custom Rear Bumper
Headache Rack
6.0l intercooler (already have one just need to pipe it)
rosewood stage 1's
custom tunes
7.3powerstroker is offline
post #3 of 10 Old 03-05-2013, 09:28 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
A couple have used an sd saddle for a front tank, but not sure how well it fits on a short box
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 10 Old 03-06-2013, 04:05 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
See thread link below...
lwillson did the swap in a ccsb, here is the link...
SD Plastic Fuel tank in an OBS
You can also get a 33gal bronco tank for the rear here...
33 Gallon Steel Gas Tank
Both the SD tank and the Bronco tank will use you current sending unit with modification.
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #5 of 10 Old 03-06-2013, 05:10 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I forgot all about Wilson's ccsb, he has that tank in the bed he built too
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 10 Old 03-06-2013, 06:55 AM Thread Starter
So the spectra and bronco tanks will fit under the rear of my short box then? And the SD short box under the front?
post #7 of 10 Old 03-06-2013, 08:24 AM
boynamedsue's Avatar
This is the route Im going. Dont let the title on the link fool you. Check it out. Performance Injectors for 7.3L Ford Power Strokes
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. - Benjamin Franklin
boynamedsue is offline
post #8 of 10 Old 03-06-2013, 04:02 PM
Hillbilly Deluxe
Quoted: 2 Post(s)
Yes x2
Thats a nice write up... But $80 for an extra 5 gal i would be getting the one from Bronco Graveyard...
Seth
Stroked_NY_023
post #9 of 10 Old 03-06-2013, 04:52 PM Thread Starter
Tanks
Plastic or steel? I know the steel will rust on the outside with snow and salt, but what about the inside?
I need to replace the front one already and will probably just do another stock one up front.
Side Mount Tank 17 Gallon, 42" long
And would rather just use the plastic Bronco one.
Gas Tank, 33 Gallon Plastic 90-96
I hope these are the ones that I need.
Thanks.
post #10 of 10 Old 03-10-2013, 05:13 PM
Hillbilly Deluxe
Quoted: 2 Post(s)
Re: Fuel Tank swap
Thanks.
Yep those are the ones!
Seth
Stroked_NY_023
