Should I worry about this? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-04-2013, 08:48 AM Thread Starter
pittdiesel's Avatar
Ill try to make as simple as I can.
Very large amount of oil consumption lately. No visible leaks. No white or black smoke. Previous post everyone told me I need new injector O-rings. Which is slated for early summer.
But should I worry about the low pressure oil guage? Lower than normal. Pretty consistent. Would I see a rise with new o-rings? Or does this mean low pressure pump going too? Been this way for few thousand miles. Just recently dipping lower it seems. Really low end on startup. Thanks guys!!!
94.5 7.3 f250
210K
Sent from AutoGuide.com App
pittdiesel is offline
post #2 of 3 Old 03-04-2013, 11:35 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
I would change the injector o-rings sooner than later. You can very easily become stranded as oil consumption can get worse (when mine failed I used 8 quarts in 150 miles). Also, depending on the failure, it can also cause a no-start. The factory oil pressure gauge is really nothing more than a glorified idiot light. The sender is nothing more than a switch that is either ON or OFF at some threshold pressure value (around 6 psi I think). Anything above that and it is supposed to read mid-scale. If you want pull the wire to the switch (on top of the HPOP reservoir) and ground it. The gauge should read mid-scale. Cheers!
Patrick Feeley is offline
post #3 of 3 Old 03-06-2013, 08:40 AM Thread Starter
pittdiesel's Avatar
Awesome. Thank you!
