efuel qusetion - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-04-2013, 05:38 AM Thread Starter
stealthrunner's Avatar
Quoted: 2 Post(s)
Question efuel qusetion
Got a efuel question for all you OBS guys....i saw some where in a efuel thread some where....and i'm after the fitting/fittings that are used to adapt an AN line to the banjo fitting in the valley to the hard lines that go to the back of the heads on my 95 7.3 obs...
and one about the fuel lines on top of the motor...
Which lines of the lines the hard lines to the back of the heads or the braided lines that hook up to the FPR are the return lins back to the tanks????? Thanks for any info!!! starting my e-fuel conversion in 2 days after figureing out my new AE program!!!!
95 F-350 4x4 Crew Cab
Mods. so far
DIY Intake
4" diamond Eye exhaust
New Toyo AT 2's
VHF/UHF Radio
Pillar gauge pod and all Isspro gauges
E-Fuel done and running!!!!
Wicked Wheel 2!! Good Mod.!!
Intercooler is in and helps alot!!!!!
100 Gallon transfer tank...
Stage 1's and a Hydra chip with tony's tunes on it!!!
Next on the list...ZF-5 swap...
stealthrunner is offline
post #2 of 8 Old 03-04-2013, 07:10 AM
Full A-Team Member
Fordman247365's Avatar
Back of the heads are feed, front is return going to FPR
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #3 of 8 Old 03-04-2013, 04:55 PM Thread Starter
Quoted: 2 Post(s)
Thumbs up
Thank you Sir!!!! Any body have an idea who's efuel build or who sells the adapter fitting that lets you use the rear feed lines and adapts to an AN line???
Will be starting efuel tommarrow!!! Lots of parts are on the way!!!
Mods. so far
DIY Intake
New Toyo AT 2's
VHF/UHF Radio
post #4 of 8 Old 03-05-2013, 02:12 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 4 Post(s)
Feedback Score: 3 reviews
Most guys eliminate the banjo and use a Y block...
Here is my favorite write up on efuel, and the one i will using when i build mine.
Electric Fuel Conversion - PowerStrokeNation : Ford Powerstroke Diesel Forum
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #5 of 8 Old 03-05-2013, 03:53 AM
Best E-Fuel right up I have seen yet!!!!!
Baileysbees is offline
post #6 of 8 Old 03-05-2013, 07:07 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
"Write up"
But it is pretty good, lots of bouncing around tho lol
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 8 Old 03-05-2013, 03:23 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
this is the fitting for the banjo bolt. you can then go to whatever you want. i went to a 3/8 hose barb
6404-12-08 | FEMALE BOSS x MALE PIPE ADAPTOR
i am running this until i get a chance to put in a Y block
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #8 of 8 Old 03-05-2013, 07:48 PM Thread Starter
Quoted: 2 Post(s)
Cool
Thanks Terry that's what i was looking for!!!!I'm still going to use my Tubes from the pump to the back of the heads..Cause they are brand new and cost A Hundy,And they don't leak Yet...
Mods. so far
DIY Intake
New Toyo AT 2's
VHF/UHF Radio
