Dual Fuel Tanks - Ford Powerstroke Diesel Forum
Old 01-06-2008, 07:48 PM
Dual Fuel Tanks
I have a 152" wheelbase 97 Crew Cab 4WD diesel with a leaking rear fuel tank. They offer three different sizes of tanks. How can I tell which one I need to purchase. I've searched the forums, but can't find the answer. Any help would be greatly appreciated.
Old 01-06-2008, 08:39 PM
I don't know much about the subject, but I assume it has to do with bed length. I would go with the largest that would fit.
Old 01-06-2008, 08:45 PM
allergic to hot weather
Send a message via AIM to 95and05 Send a message via MSN to 95and05
both of mine are in the owners manual... not part #s but tank sizes that would be someplace to look if you have 1.
Old 01-06-2008, 09:15 PM
Thanks for the reply's. Unfortunately I don't have the owners manual, wish I did. Any other suggestions.
Old 01-06-2008, 09:42 PM
Look under the truck to find out, but I believe you could make all 3 tanks work if you had to,just by getting the tank straps for which ever tank ya get. Somebody will be along that has "been there, done that" that can give ya better answers than me.
Old 01-06-2008, 10:10 PM
I hope so... Thanks for the reply.
Old 01-07-2008, 12:04 AM
Call or stop by a Ford parts dealer with your vin, they can tell you all about it.
Old 01-07-2008, 05:30 AM
im not sure but i think you could check the driver side door jamb
Old 01-07-2008, 02:15 PM
I think the rear option is plastic or steel but the are all 18 or 19 gallons, the side tanks are different sizes 17 or 19 gallons I believe
later,
DEVLYN
Old 01-07-2008, 02:47 PM
Infidel
I have seen a mod where you put a tank from an 86 - 97 bronco (last year might be wrong). IIRC you fill up in the bed of the truck. Apparently, the single tank holds 40 gallons. Good chance my numbers are slightly off.
Craig
