Levelling kits...do I want/need one? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-03-2013, 04:58 PM Thread Starter
Quoted: 2 Post(s)
Sure...my tail end is a bit closer to the ground than the front, but is this a big deal?
I'm looking at some levelling kits here at: Ford F250 Leveling Kit - Best Leveling Kits for Ford F250 Super Duty Trucks - 2WD Rear & Front Leveling Kit Reviews - XLT & PowerStroke - 1968 - 2013 and they're not too expensive...are these good enough for the PSD or do I have to go to something HD?
Which one of these would YOU choose?
97 F250 PSD...6637 Filter upgrade...3" Diamond Eye DP...DFuser EBPV eliminator...Improved "Blue" CPS...
Qwazert is offline
post #2 of 5 Old 03-03-2013, 07:51 PM
sethc24's Avatar
If you dont tow or put heavy loads in the bed a lot i would get a set of F-350 blocks and put em under the back. If you tow a lot i would get the firestone airbag helper kit and mount them so when they are inflated you gain a couple inches of lift.
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
post #3 of 5 Old 03-03-2013, 08:02 PM Thread Starter
Quoted: 2 Post(s)
Pardon my ignorance..."F-350 blocks"?
Are you talking these things? http://www.autoanything.com/suspensi...A4141A0A0.aspx
Qwazert is offline
post #4 of 5 Old 03-03-2013, 08:07 PM
7.3powerstroker's Avatar
F350 come with bigger blocks in the back. They are 3.75 inches I think. F250 comes with 2 inch blocks
Sent from AutoGuide.com App
Shelby
1995 F350 7.3l
5 speed
240,000km
DIY Intake
3.5"dp to 5" straight pipe
99 Turbo and Spyder
6" Lift
37" BFG KM2's
Harley Davidson Leather buckets
Grant Steering Wheel
Autometer Gauges Pryo,Boost
CB Radio
Custom Bumper(built it myself)
Clear Headlights (black background)
Black Grille and Headlight Trim
Soon to come
Custom Rear Bumper
Headache Rack
6.0l intercooler (already have one just need to pipe it)
rosewood stage 1's
custom tunes
7.3powerstroker is offline
post #5 of 5 Old 03-04-2013, 07:26 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
^the spacer between the axle tube and leaf spring. _shudder_ $150 for 4 u-bolts and two pieces of plastic! Hit the wrecker and pull them from a dead truck.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
