Low Boost on Edge Insight? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-03-2013, 07:30 AM Thread Starter
Question Low Boost on Edge Insight?
So I just installed a Edge Insight CTS. Awesome unit, can't believe hoe many parameters it reads off the obs...even manual tranny fluid temp! Anyway, the boost numbers its giving me make no sense. I took it out and got on it a bit-rmps up toward 3000 and the turbo was singing loud (for a stock one) but the gauge only hit 8psi max! I can feel the boost, hear it, so what gives? I have basically a stock set up except a AFE drop-in and a 3"dp to 4" exhaust. Is this a sensor issue or could my boost really be that low? It feels and sounds like it should be much higher, based on other rigs I've been in...
Ideas?
Thanks
97stick is offline
post #2 of 4 Old 03-03-2013, 08:32 AM
It's reading of the map sensor, get the EAS pressure sensor and tap your intake y as it come out of the turbo and you will get an accurate reading, you won't see much more boost stock, but it will be accurate
2000 F350 Lariat dually 6 speed 4" mbrp, 6637, Banks brake. Just rolled over 60k miles
2016 keystone cougar 333mkswe
2016 Ford Escape Titanium 2.0 ecoboost
2014 vw Jetta sportwagen tdi. sold
1995 dodge 2500 drag truck. 6.82@104 in the 1/8th. Sold
1996 dodge 2500 auto. sold
1997 F250 auto. sold
1997 F250 5 speed. sold
1998 dodge auto 2500. sold
2001 dodge 5sped 2500. sold
2003 F250 6.0 auto. sold
2004 F350 6.0 6 speed. sold
ctd12valve95 is offline
post #3 of 4 Old 03-03-2013, 10:15 AM
Stock you should hit 15psi mine stock got lucky and ran from 18-20 psi stock with no tunes gettin 23-24psi with chip and an up pipe leak
Ben
1995 Ford F-350 Centurion package
6637
3" Diamond Eye down pipe
4" back to 7" stack
PHP tuned 6 position chip
140V IDM Mod
Custom paint obsidian black/medium copper
Custom tow mirrors
95350PS is offline
post #4 of 4 Old 03-04-2013, 08:24 AM Thread Starter
Thanks. EAS pressure sensor is ordered.
97stick is offline
