96 7.3 blue smoke when cold and rich exhaust all the time - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-02-2013, 01:13 PM Thread Starter
Sure would like some straight forward solid information, seems post go all over the place and dont stay specific to issue or never see solution. My 96 has 310000 and running strong , no problem starting, idles like new, and strong as ever. Just more smoke than usual on start up and has eye burning exhaust most all the time , even after interstate run , stop to stretch and "GEEZE" she stinks! Hate to throw injectors at it even though its WAY past time HA just would like some straight talk to guide me in the right direction. Thanks
jastone502 is offline
post #2 of 8 Old 03-24-2013, 04:06 PM
I am having the same issue, got a 94.5 that has 25K miles on a rebuild. Truck is not my daily driver, has no codes, no mods, and the exhaust actually drips diesel at times.
AKwelder is offline
post #3 of 8 Old 03-24-2013, 06:57 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Are you guys experiencing more fuel consumption than average? Could need an injector rebuild from leaky injector cups, hope someone can point you in an easier cheaper fix, and sorry we have a hard time not derailing threads here
Btw to the both of you welcome to the org
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 8 Old 03-25-2013, 06:06 AM
Full A-Team Member
Fordman247365's Avatar
Can be any number of things, low compression, sticking injectors, not enough air....
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #5 of 8 Old 03-25-2013, 04:54 PM
stroken96's Avatar
My truck is the same way and its got 189,000 on it, i dont drive it much but think injectors need rebuilt
stroken96 is offline
post #6 of 8 Old 03-26-2013, 08:37 PM
My apologies to the original poster, I have the same issue, not trying to thread jack you
My fuel economy is horrible. The truck was sitting in a yard, one head in the bed, and a pile of parts on the floor. The block was cracked on #6 cylinder. I started the rebuild, had the block sleeved on all 8 holes, and ran out of time. Went to a good shop, and it hurt, but was done right including a new turbo. I had a new down pipe installed while i was doing it, and cut off the cat. That was 6 years ago, truck started running ritch about a year later
I have been searching threads and had decided my most likely issue is the 19 year old injectors. Computer wise I don't know what could be off, map sensor? CPS?
Any help would be great
AKwelder is offline
post #7 of 8 Old 03-26-2013, 08:38 PM
The RPM function on my high idle box quit, any link to CPS?
AKwelder is offline
post #8 of 8 Old 03-26-2013, 09:06 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 126 Post(s)
If you're getting bad smelling exhaust, check your compression before looking at anything else.
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
