"wait to start light?" - Ford Powerstroke Diesel Forum
post #1 of 21 Old 01-04-2008, 03:48 PM Thread Starter
ok.. 1997 PSD with 213k miles, new fuel pump and sensor, running delo400 , temp here just dropped to mid 20's and now back up to 50-60. it will turn over but not fire. my wait to start light will not come on as well. Should i start with the GPR? i will have to get a multimeter tomorrow but wanted to some advice as where to start. much thanks in advance
sydeshowbob is offline
post #2 of 21 Old 01-04-2008, 04:12 PM
That's where I would start. You should get atleast 12v going to go it.
2000 F-350
7.3L 6spd 71xxx miles
Zero Mods
3/01/2008 - 3/25/08
Zoodad and Foil Delete 3/26/08
DIY Intake 6/25/08
4" TB exhaust 7/01/08
TW 6pos chip 7/27/08
HP oil crossover 7/27/08
'05-'07 Front end conversion 1/8/10
UnlimitedLove is offline
post #3 of 21 Old 01-04-2008, 04:14 PM
Check fuses, big one in box right fenderwell.
Diesel Monkey is offline
post #4 of 21 Old 01-04-2008, 04:15 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Yep I would start there as well. Here is a writeup to helpTroubleshooting GPR & GP's
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #5 of 21 Old 01-04-2008, 04:16 PM
vitalidle's Avatar
Yep good advice could be the fuse for the fuel heater element I think #22. If its burnt then more than likely you will have to unplug your element so it won't continue to blow the fuse.
Auto 93,000 miles
DP Tuner F5
post #6 of 21 Old 01-04-2008, 04:52 PM Thread Starter
again - thanks for the quick response.. i will try look at the fuse and test for 12v. and get back with everyone.
post #7 of 21 Old 01-04-2008, 05:06 PM
sldghamr's Avatar
i had that exact problem just a few days ago. would crank and not fire, tach wouldn't move, and wait to start light wouldn't come on. ended up being the fuse for the computer had gone out.
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #8 of 21 Old 01-04-2008, 06:19 PM
Powerstroke Techie
alabamafrog's Avatar
I admit I don’t know a thing about the OBS trucks but on my truck the wait to start light has nothing what so ever to do with the GPR or the glow plugs. It is fired by the computer and usually means the computer has lost power (blown fuse) or is fried. I hear that the OBS trucks are bad a bout blowing #22 when the fuel heater shorts out and all you have to do is unplug the heater and replace the fuse and forget it.
“Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one” (T Paine)
Government cannot give anyone anything without stealing it from someone else. (A Frog)
alabamafrog is offline
post #9 of 21 Old 01-05-2008, 06:28 AM Thread Starter
yup, it was the #22 fuse in the distribution box. I am gonna replace and see if that works.
post #10 of 21 Old 01-05-2008, 06:33 AM
SMKSTAX's Avatar
Don't forget to disconnect the fuel heater wire or the fuse will blow again.
RICK
97 F350 CREW CAB 4x4, 7.3 TURBO DIESEL, DIY INTAKE , TW TUNES
GRAND ROCK POWERFLOW STACK KIT W/5" MITRES
3.55 REARS, 3" DOWNPIPE, FPR SHIMMED WITH GAUGE
SMKSTAX is offline
