Stage ones - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-01-2013, 05:10 PM Thread Starter
HOYBOY's Avatar
Stage ones
Can I run stage one injectors with out a chip?
SLOW STROKIN
2006 6.0 Amarillo
95 Ford F250 4x4 7.3 blue Charlene (sold)
94.5 Ford F250 4x4 7.3 Green two-tone Tracy (junked)
HOYBOY is offline
post #2 of 6 Old 03-01-2013, 05:52 PM
jjones96's Avatar
Yes sir you can. I have a buddie that has stage 1s and no chip. And it s kinda slow to be honest. My truck has more power and i just have a tuner
The STROKE
1996 F-250 Powerstroke
7.3 DI T444E.
TS 6 Postion chip
Gloshift max tow gauges
3 inch dp to 5 inch exhaust
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
Redneck weight reduction
The work truck
2012 Ford F-350 DRW 6.7 Powerstroke
C&M Flatbed
100 gallon slip tank
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #3 of 6 Old 03-01-2013, 06:04 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Re: Stage ones
Not splits though. Well, poorly I guess
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 6 Old 03-02-2013, 07:46 AM
dazed01's Avatar
I did for a day and it was very smokey.
Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars.
dazed01 is offline
post #5 of 6 Old 03-02-2013, 08:08 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Stage 1's will act and put out like stock unless you tune them, hybrids will be smokey with no tune, and you should be able to push stage ones with a healthy stock hpop as well when tuned
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 6 Old 03-02-2013, 08:16 AM
JD3020's Avatar
Like Kris said, 1's will run just like a bone stock truck. You may notice some improvements though by going from worn injectors, to fresh injectors.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
