Lockers for our trucks - Ford Powerstroke Diesel Forum
post #1 of 18 Old 03-01-2013, 05:41 AM Thread Starter
1997 Ford F-250
I have limited slip on my truck now but it isn't working. Instead of trying to fix it, I would rather just get something else that is going to work. I have read all about the detroit locker and truetrac lockers and really not interested in those. I would rather just have something that I flip a switch and it locks. I mostly am needing it for when I am pulling my boat out of the water. Does anyone offer electronic locker for our truck?
My next question, if no one offers e-lockers and I have to use an air locker, how much air does an air locker use? Can I just mount a tank under my truck and charge it up with my home compressor to avoid having to pay for a compressor?
I searched a lot on here and couldn't really find anything definitive. Thanks for the help.
tucker0104 is offline
post #2 of 18 Old 03-01-2013, 09:18 AM
erics diesel's Avatar
If you have ls already when is the last time the differential fluid was changed and a friction modifier added?
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 18 Old 03-01-2013, 09:23 AM Thread Starter
I changed it about 2 months ago and have only driven it about 500 miles. No friction modifier was added.
post #4 of 18 Old 03-01-2013, 10:17 AM
ARB air locker or Eaton E-Locker would be two options.
sgg93 is offline
post #5 of 18 Old 03-01-2013, 10:54 AM Thread Starter
Do you have a link for an e-locker for a 10.25? I can't find one.
post #6 of 18 Old 03-01-2013, 12:21 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
I do not believe anyone makes a e-locker for the sterling 10.25
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #7 of 18 Old 03-01-2013, 01:47 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Isnt there a company that makes a cable actuated locker, looks like a choke cable in the truck. Pull it and its locked!
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #8 of 18 Old 03-01-2013, 02:12 PM Thread Starter
If there is then let me know. I would be fine with pulling a cable.
post #9 of 18 Old 03-02-2013, 07:38 PM
toad's Avatar
Quoted: 16 Post(s)
Cable locker is made by OX Locker. Dont offer one for 10.25. ARBs are great. I have them in the front and rear of my Jeep. Air volume that is required is very minimal. They do need 100 psi. Compressor is handy to have. The factory limited slips are garbage compared to a real locker. If you do decide to get a air locker make sure that whoever installs it knows what they are doing. The majority of air locker issues are from install.
toad is offline
post #10 of 18 Old 03-03-2013, 06:10 AM
ol_Blue97's Avatar
Yup, ox lockers.... there are only 3 locker options for a 10.25, ARB, true-trac, and lock-right. Not sure if you could remove the internals out of a 2012 superduty and swap into the older 10.25 housing. That would give u a e-locker ??
FRANK THE TANK
