EBPV problems...help! - Ford Powerstroke Diesel Forum
Old 01-03-2008, 08:16 AM
EBPV keeps activating every time i touch the fuel pedal. '96 psd, about thirty degrees this morning, gave truck about fifteen min to warm up. driving down the road the valve kept activating EVERY time i even touched the fuel feed. anybody have any ideas...thanks
Old 01-03-2008, 08:18 AM
Desert Shield/Storm Vet
You could unplug the solenoid while the truck is off should cure it from closing.
Old 01-03-2008, 10:14 AM
Mine does it too. I just deal with it, it will eventually go off. If your cruising on the pedal and its on give a light tap in the pedal it will go off for about 5 seconds
Old 01-03-2008, 10:36 AM
allergic to hot weather
Send a message via AIM to 95and05 Send a message via MSN to 95and05
put it on a toggle in the can so you can use it to warm up or as engine brake. then when toggle off it won't close
Old 01-03-2008, 02:03 PM
thanks for all your input i will try it when i get home from work in the morning
Old 01-03-2008, 02:17 PM
Shaking the Bush Boss
Unplug it.
