Crank, no start. . . - Ford Powerstroke Diesel Forum
post #1 of 17 Old 02-28-2013, 06:31 AM Thread Starter
Jack T.'s Avatar
I'm gonna do what I hate to see people do. . .beg for help with a very low post count.
1995 7.3. 200,000 miles. New (10,000 miles ago) valve cover harness and #8 injector.
Truck was warm, ran home to grab a tool out of the shop, came back out and it idled *horribly*. Killed the truck. . .and it hasn't started since.
Replaced fuel filter and CPS. Drained fuel bowl and the fuel pump seems to be working. . .fuel goes back into the bowl.
Switched tanks, thinking bad fuel, and still no start.
WTS light comes on and tach moves on cranking.
White smoke while cranking.
I did drive through several large puddles on the way home (hey, it's been so long since we had rain here in Oklahoma I couldn't resist playing in it some!)
That give enough clues for somebody to make a SWAG?
I had somebody suggest the GPR, but the fact that the truck wouldn't start when it was a operating temperature makes me think it isn't the GPR. . .
Jack T. is offline
post #2 of 17 Old 02-28-2013, 07:50 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
What is fuel pressure? When was the last time you cleaned the FPR screen? When you crank it does it crank fast and strong or slow and kinda lope-y?
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 17 Old 02-28-2013, 08:01 AM Thread Starter
Jack T.'s Avatar
1) Unknown. . .but fuel *gushes* out of the drain when cranked
2) Never. . .I'll try that this evening
3) It cranks fine. . .slower now that I've been fighting it for 3 days, but still fast enough (in my opinion) to start. I figured I could have the lovely Mrs. Jack pull it with the tractor to rule out a low battery/crank speed.
Jack T. is offline
post #4 of 17 Old 02-28-2013, 08:06 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Unless the tractor can pull it fast the PCM needs to see a minimum of 300 RPM before allowing the IDM to fire the injectors. On the side of the fuel bowl is a Schrader valve that if you pull out the stem you can add a real fuel pressure gauge. On the cheap you can waste a tire gauge without removing the stem to see what the cranking pressure is. These stock fuel pumps are two stage. The first is a high volume low pressure stage that pulls from the tank and fills the bowl. Then the fuel is pulled back from the bowl and the pressure is stepped upped to about 55-60 PSI right before it is sent to the heads.
Are there any fluids in the engine valley?
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #5 of 17 Old 02-28-2013, 08:17 AM Thread Starter
Jack T.'s Avatar
I'll check the valley again this evening. . .there *is* fuel around the upper valve cover bolts, but that is (I think. . .I didn't notice it before) from where I had the old fuel filter resting while installing the new one.
Jack T. is offline
post #6 of 17 Old 02-28-2013, 08:48 AM Thread Starter
Jack T.'s Avatar
Hang on. . .since it is blowing white smoke while cranking, wouldn't that rule out a fuel delivery problem?
Jack T. is offline
post #7 of 17 Old 02-28-2013, 08:59 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Kinda depends on quality of the delivery of said fuel. White smoke more or less means the fuel is too condensed (thick if you will) or the cylinder too cold for proper self ignition of the fuel. With poor fuel pressure at cranking speeds the injected fuel may not be atomizing very well and big fuel droplets are harder to burn cold. Or the injector is not delivering enough fuel for self ignition.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #8 of 17 Old 02-28-2013, 09:19 AM
superduty4x4's Avatar
UVCH.........
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #9 of 17 Old 02-28-2013, 09:28 AM Thread Starter
Jack T.'s Avatar
Originally Posted by superduty4x4 View Post
UVCH.........
Those were both replaced a year or so ago. . .maybe 18 months ago now. I guess one/both could be bad. . .
Jack T. is offline
post #10 of 17 Old 02-28-2013, 09:42 AM
clatterindiesel's Avatar
How much water did you splash in? Did you ford a river or drive through a pudle 1/4" deep? Maybe got water in IDM
I live close to ocala and surrounding areas, so if anyone ever needs a hand with their truck....get a hold of me.
clatterindiesel is offline
