Fuel Gauge - No reading? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-28-2013, 03:15 AM Thread Starter
ja9788's Avatar
My fuel gauge worked great until recently when I installed my gauges. To be specific, I hooked up my fuel pressure gauge and now it constantly reads empty. It worked sporadically for a few days going up and down trying to read but always finding its way to empty. I checked the fuses and they seem fine. I'm just curious if anyone has ever ran into this problem? I would work on it more to figure it out I just don't have a lot of time since this is my dd and I work two jobs and go to school
< Joel >
95 F350 SCLB 4x4
- WW2
- 3" DP to 4" Straight pipe
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #2 of 8 Old 02-28-2013, 03:53 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Did u remove any grounds under a screw to add your gauge ground? Usually a bad fuel gauge is a ground issue
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 8 Old 02-28-2013, 04:05 AM
Quoted: 53 Post(s)
Same thing on both tanks?
madpogue is offline
post #4 of 8 Old 02-28-2013, 07:15 AM Thread Starter
ja9788's Avatar
Sorry forgot to mention it's the cluster fuel gauge not a separate aftermarket. Yes it reads the same with both tanks. I just replaced the rear sending unit like three weeks ago.
< Joel >
95 F350 SCLB 4x4
- WW2
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #5 of 8 Old 02-28-2013, 07:17 AM Thread Starter
ja9788's Avatar
Nope. Just added a few 12v's and grounds. I didn't really have to take much apart to add the gauges.
< Joel >
95 F350 SCLB 4x4
- WW2
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #6 of 8 Old 03-04-2013, 03:01 PM Thread Starter
ja9788's Avatar
Food for thought anyone?
< Joel >
95 F350 SCLB 4x4
- WW2
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #7 of 8 Old 03-04-2013, 05:20 PM
ol_Blue97's Avatar
If u replaced the rear sending unit i would look for a pinched wire around that area
FRANK THE TANK
post #8 of 8 Old 03-05-2013, 02:48 PM
A fuel gauge basically reads resistance to ground in ohms. A easy test is to remove fuel sender plug and touch the sender wire that goes to gauge to ground. Gauge should peg full with sender wire grounded. Not sure off top of head which wire is the sender wire.
Streamin is offline
