How much do you vibrate? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-27-2013, 05:17 AM Thread Starter
At highway speeds how much does your truck vibrate when you're on the throttle vs off?
My truck notably vibrates when on the throttle vs off. Curious if that is the norm.
Sent from AutoGuide.com App
1995 f-350, 108,000 miles and climbing, second motor with approximately 130,000 miles on it.
DIY Intake, stage 2 injectors from Rosewood, 3" DP to 5"side dump with a 6" Tip
HPOP, 6.0 IC (anyone have a spyder?) and E fuel to come
wakeboardin2k4 is offline
post #2 of 11 Old 02-27-2013, 05:52 AM
superduty4x4's Avatar
Have you checked the carrier bearing or the u joints? That doesn't sound normal to me.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #3 of 11 Old 02-27-2013, 09:42 AM
JD3020's Avatar
My truck used to do something similar. Found a bunch of loose transmission bolts.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #4 of 11 Old 02-27-2013, 12:45 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Mine does that at 72-75 mph and higher and lower none at all, I'm replacing u joints before I take it cross country again
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 11 Old 02-27-2013, 01:00 PM
Quoted: 4 Post(s)
nope, no vibration
timlsalem is offline
post #6 of 11 Old 02-27-2013, 02:49 PM
I got some but pretty sure mine are due to crappy body mounts
Ben
1995 Ford F-350 Centurion package
6637
3" Diamond Eye down pipe
4" back to 7" stack
PHP tuned 6 position chip
140V IDM Mod
Custom paint obsidian black/medium copper
Custom tow mirrors
95350PS is offline
post #7 of 11 Old 02-27-2013, 04:05 PM
sethc24's Avatar
my nokien vativa mt tires are super bald so my truck vibrates constantly on and off the throttle.
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
post #8 of 11 Old 02-27-2013, 05:42 PM
Aw9414's Avatar
My truck only vibrates at 70-80 because of the tires i have on it.
-Austin-
1996 cclb F350 lifted 7 inches on 35s SOLD
New truck 1997 f350 on 37s with 170k
Aw9414 is offline
post #9 of 11 Old 02-27-2013, 05:44 PM
boynamedsue's Avatar
None here at any speed.
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. - Benjamin Franklin
boynamedsue is offline
post #10 of 11 Old 02-27-2013, 07:59 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
I only have a slight vibration at take off, 5-10mph... its my carrier bearing.
Make sure your hubs arent locked in, check your u-joints, and carrier bearing, and have your tires balanced, check for abnormal wear on the tires front and rear that may give a clue to what it is.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
