A Few Issues oil boost brakes - Ford Powerstroke Diesel Forum
post #1 of 16 Old 02-26-2013, 03:07 PM Thread Starter
Ok got a few issues mods are in sig
Truck before php tunes was hitting 22psi of boost with intake exhaust and IDM Mod now with the php tunes only hitting 24psi boost thought the custom tunes would add more than 2psi
My oil pressure gauge in the cluster isnt working right sometimes doesnt work sometimes bounces in the low range done this sinše i bought it a year ago
BRAKE light came on driving home from work tonight brakes work same as before checked the abs fuses checked fluid levels and i got no abnormalities
School me on my knowledge guys please lol
Ben
1995 Ford F-350 Centurion package
6637
3" Diamond Eye down pipe
4" back to 7" stack
PHP tuned 6 position chip
140V IDM Mod
Custom paint obsidian black/medium copper
Custom tow mirrors
95350PS is offline
post #2 of 16 Old 02-26-2013, 03:36 PM
Full A-Team Member
Fordman247365's Avatar
TBH 24 psi on stock sticks aint bad.....
Edit: The brakes could need adjustment in the rear....
Edit again: Make sure the E-brake pedal is all the way up
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #3 of 16 Old 02-26-2013, 03:40 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Kinda shocked you were getting 22 with out tunes
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 16 Old 02-26-2013, 03:41 PM
rodgerdathug's Avatar
Quoted: 2 Post(s)
Ok with the brake does it seem to get a little stiff. It might be your vacuum pump
rodgerdathug is offline
post #5 of 16 Old 02-26-2013, 03:44 PM Thread Starter
Well the brakes from time to time when i rank the wheel alot as in like backing out of a tight spot then crank back the brakes will go almost to the floor before they grab then they build back up and they're good
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
post #6 of 16 Old 02-26-2013, 03:52 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
send me your email address and i will email you the brake info Matt sent me it's very complete.
boost is pretty normal.
oil pressure could be a bad sending unit or a bad connection. i had a problem with mine and it was a loose connection. you can have someone wiggle it under the hood whille you watch the gauge
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is online now
post #7 of 16 Old 02-26-2013, 03:59 PM Thread Starter
Ok so also are the ipc and ipr testable wondering if the injectors are getting enough oil for the mods i have
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
post #8 of 16 Old 02-26-2013, 04:24 PM
the baconator
Quoted: 143 Post(s)
high pressure oil pressure is. i think frank told yo how to do that
post #9 of 16 Old 02-26-2013, 04:26 PM Thread Starter
Yeah i thought that would only test the hpop itself not the sensors
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
post #10 of 16 Old 02-26-2013, 04:28 PM
the baconator
Quoted: 143 Post(s)
it will, but you asked if your injectors were getting enough oil. it will tell you that.
