Looking for help separating downpipe - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-25-2013, 09:57 PM Thread Starter
Send a message via AIM to mpdxtreme
OK a couple of years ago I had a local diesel shop (and I use that term loosely) install my MBRP exhaust. Nothing special just a 3 in downpipe and 4 in from down pipe out the back. Every since I had it installed I've alwasy had a vibration/knock and could never locate it. After taking the turbo and looking around I found that the shop DID NOT cut and bend the cab pinch weld. Its almost rubbed a hole in my downpipe it was so bad. Anyway here is where I am loking for help. I am trying to get the downpipe separated from the rest of the exhasut system without destroying something. I have been soaking the joint with Deep Creep and PB Blaster every day. I have banged, pried, tried to twist, and several other things but cant get it separated. Also if anyone has any pics of cutting and bending the pinch weld that would be helpful also.
Thanks
James Gaddy
mpdxtreme is offline
post #2 of 6 Old 02-25-2013, 11:57 PM
JSchuricht's Avatar
If you had a u-bolt stlye clamp your going to have to cut it out.
JSchuricht is offline
post #3 of 6 Old 02-26-2013, 07:01 AM
superduty4x4's Avatar
Bingo. To get those "bear clamps" or u-bolt style clamps tight enough to seal, you have to pinch the tubes together which makes them damn near impossible to separate without cutting. If I were you, I'd just order a new down pipe and an SS band clamp so that if you ever have to pull it apart again, it will come apart easily. Plus you'll have a bit more clearance at the firewall with a band clamp.
Probably $8-10 at Napa.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #4 of 6 Old 02-26-2013, 07:56 AM Thread Starter
My downpipe didnt have a clamp where it goes into the exhaust. I guess its just "frozen" in because its been in there for a while. If I cant get it out in a few more days I am going to get the sawzall after it and then order a new downpipe.
The thing that really makes me mad is this is just one more thing that I've paid to have done and it wasnt done right. I knew better than to let someone else do it but I didnt have time. O well lesson learned, again, dont let anyone else work on my truck.
1996 Ext Cab F250 PSD with 176xxx miles and climbing. MBRP 3 in downpipe into 4 in exhaust, EBPV deleted, AFE intake
post #5 of 6 Old 02-26-2013, 09:03 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Use a torch with a 45* braising tip to heat the outer section of pipe. This will cause the outer pipe to expand off the inner pipe. Twist and pull apart.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #6 of 6 Old 02-26-2013, 01:21 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
^^^ what he said. But if it has been pinched, u may be getting the sawzall out. BAND CLAMPS FOR THE MOTHA FU**IN WINN!
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
