Chip or Flash? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-25-2013, 06:38 PM Thread Starter
Chip or Flash?
Which is better?
I've seen the video where the HPOP guy says the Flash is better because it won't cause codes.
Chip tunes seem kinda dodgy - have to be held in with tape - so what is the consensus?
97 F250 PSD...6637 Filter upgrade...3" Diamond Eye DP...DFuser EBPV eliminator...Improved "Blue" CPS...
Qwazert is offline
post #2 of 6 Old 02-25-2013, 06:43 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
I would agree flash would be more reliable if you are always going to run only a single tune. If you want the option of multiple programs that you can switch on-the-fly, you will need a chip. Cheers!
Patrick Feeley is offline
post #3 of 6 Old 02-25-2013, 07:29 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Exactly why I agree with Patrick. Driving tunes, towing tunes, performance tunes all at the flick of a switch. Also, I have not had a chip induced error code.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 6 Old 02-25-2013, 08:17 PM
d7es3l's Avatar
Chip or Flash?
I like the idea of the 6pos. I feel like a flash wouldn't be as efficient though.
d7es3l is offline
post #5 of 6 Old 02-25-2013, 09:29 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
With the flash you have to spend 5 minutes messing with it every time you chane a setting, both the edge and my custom tunes make my truck throw a code simply because there just wasn't enough oil tho, I say go with a chip
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 6 Old 02-25-2013, 09:49 PM
Brent Beeler's Avatar
Chip or Flash?
FYI I've had the edge juice w/attitude platinum on my 07 6.0 loved the ability to change power levels on the fly and the turbo timer was nice too, however after a harness on the unit went bad twice and it caused the truck to do some very strange things I got rid of it and went with a SCT Liveire TS with custom tunes from IDP and it hasn't given me any problems, and the power is awesome. For reliability I'd definitely go with a programer instead of a chip, just less to go wrong. IMO.
Sent from AutoGuide.com App
Brent Beeler is offline
