E4OD to ZF5 swap - Ford Powerstroke Diesel Forum
Old 02-24-2013, 07:11 AM
E4OD to ZF5 swap
I want to put a zf5 in my truck. I found two out of idis, one 2x4 and the other 4x4. My truck is 4x4 which I would need. Do the idi zf5s fit on a 7.3 powerstroke? Also, what would be needed to convert a 2x4 into a 4x4?
Old 02-24-2013, 09:19 AM
any zf from a 7.3 will work. However you do want the 4x4 trans.
Old 02-24-2013, 10:01 AM
Will there be any special things because its from an idi
Old 02-24-2013, 11:29 AM
It's not rated to hold as much tq, but will be fine behind a slightly modded psd
Old 02-24-2013, 01:25 PM
My plans were to put a southbend clutch in and my HP goal is 400-450 will it hold it?
Old 02-24-2013, 01:36 PM
It should be fine, but I'm not sure as to what makes the idi trans and psd trans different I just know they are not rated as high from the factory, go ahead an do a smf while your at it tho, dmf is known to grenade and blow apart the case
Old 02-24-2013, 01:40 PM
What's a smf
Old 02-24-2013, 02:05 PM
Single Mass Flywheel.
Old 02-24-2013, 02:35 PM
I know the southbend comes with a flywheel. Is it single mass
Old 02-24-2013, 04:00 PM
Also, how much would it cost to convert a 2wd to 4x4 because the 2wd is $250 cheaper then the 4x4 is.
Tags
2x4, 4x4, idi, swap, zf5
