intermittent tach.... but engine runs fine? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-24-2006, 09:19 PM Thread Starter
Still sorting this new well-used truck out.
Every so often, the tach quits working when driving. Or it just doesnt work when I fire the truck up. But even if it doesnt work when i fire it up, it normally starts working a few minutes afterwards.
The engine runs fine, no matter what the tach does.
What gives? What sensor does the tach get it's signal from?
beater96PSD is offline
post #2 of 9 Old 08-24-2006, 09:38 PM
Power Strokeaholic
super_stroke's Avatar
the tach gets its signal from the cps. if thats not working then the wont run. but yours runs so im guessing that theres a short in the cluster. whats it do over bumps? is there any consistancy to it?
Bill
2000 f-250 4x4 ex cab 7.3 psd. diablo programmer, TS 6 pos.
, 4" exhaust turbo back w/ 5" stacks, wicked wheel, HX cross over, zoodad mod, 6637 mod, boost pyro & trany on the a pilliar. 315/75/16 bfg mt's,.superwinch hub's, 6.0 trans cooler, banks trans command. sky jacker leveling kit
super_stroke is offline
post #3 of 9 Old 08-24-2006, 09:52 PM Thread Starter
Yeah, it is definately not related to engine operation. I figure it is a short or something.
As for consistency, none that I can find.
Ive got to pull the dash trim to clean out the lens, so Ill pull the cluster too.
Hopefully it's a simple fix.
post #4 of 9 Old 08-24-2006, 09:54 PM
Power Strokeaholic
good luck to ya, if it's not consistant it probably is a short. check back in the morning cuz im sure marc would have a suggestion or two
Bill
post #5 of 9 Old 08-27-2006, 03:17 PM Thread Starter
Well, story hasnt changed.
I pulled the cluster, cleaned it out, ad cleaned up the contact points between the harness plugs and the cluster. No change.
Strange though, lately, it seems to want to work, but fails to. I can see it moving, but VERY low on the gauge. barely off the low RPM stop.
Could the tach itself be failing?
Thanks for any help
1996 PSD 4x4 "Rancher Special"
post #6 of 9 Old 08-27-2006, 03:43 PM
honestly you would need to get into some pretty complex electrical testing to know what the problem is for sure, but to me this sounds like the tach itself is going out...
mschn99 is offline
post #7 of 9 Old 08-27-2006, 06:12 PM Thread Starter
Well that stinks.
I kinda figured that.
Oh well, it still runs great
Can you swap out individual gauges in the clusters? Or would it be easier just to swap clusters?
post #8 of 9 Old 08-27-2006, 08:07 PM
overl0rd's Avatar
I think you can swap individual gauges. Not that it would be easier than swapping clusters but you at least wouldn't have a vehicle with an odometer discrepancy. Plus you'd probably have to recalibrate the PSOM if you swapped clusters.
'96 F250 4x4 Ext Cab, 5 speed. K&N FIPK - modified to use 6637; 3" downpipe, 6" stack; Beans modded IDM; Beans stage 2s; shimmed FPR; exhaust brake; 6 position TS; locked 4.10s
'93 F250 4x4 regular cab long box. 7.3IDI nonturbo/E4OD 8' Western. STAYING STOCK
'65 Pontiac Tempest, 406ci chevy small block, TH350 with shift kit, 2700 stall converter.
'01 HD XL1200S - Lots of Screamin Eagle goodies
'96 Tbird LX V8
Progressive loves me
overl0rd is offline
post #9 of 9 Old 09-04-2006, 06:48 PM Thread Starter
PSOM? What is that?
Thanks for the help BTW. At this point, Im probably just going to go without a tach if it fails alltogether. If it wasnt an auto, Id probably fix it
