96 fuel filter change - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-25-2007, 07:13 AM Thread Starter
I found instructions on how to change filter on a 2002.Is the 1996 the same procedure?Any on line how to do work on powerstrokes?
Thanks Again
tony
tony65 is offline
post #2 of 9 Old 12-25-2007, 07:17 AM
KVFD
redstroker_2002's Avatar
ya should be!!! what filter u wanting to change?
-Josh
2008 2500 LMM- Deleted, Blocked, Fueled, & Tuned by:
redstroker_2002 is offline
post #3 of 9 Old 12-25-2007, 09:36 AM Thread Starter
Fuel Filter
Fuel Filter,
Thanks,
tony
tony65 is offline
post #4 of 9 Old 12-25-2007, 09:52 AM
benderado's Avatar
If your talkin' about the fuel filter/ water seperator its real easy. Lookin' at the motor there is the black plastic powerstroke over on the top of the motor. Open it up the right under there, you'll see a cap. use a screwdriver to stick in the slots of the filter cap. pull out the old filter, put in the new one. the only thing is to make sure the oring for the cap goes on the correct way. If you got any more ?'s feel free to ask me.
HI.....I'm Kyle
RIP: 1996 F-250 X-Cab Long Bed
Now: 2006 Ram 2500 CC SB SLT 6 Speed
benderado is offline
post #5 of 9 Old 12-25-2007, 10:41 AM
Shaking the Bush Boss
CHUCK's Avatar
Id be sure to drain at least 1/2 the fuel in the seperator, incase there is any water in the bowl. Just turn the yellow handle on the valve. Theres a drain hose that runs down the right side of the engine. Place a drain pan under the truck, to catch most of the drained fuel.
Chuck
CHUCK is offline
post #6 of 9 Old 12-25-2007, 05:07 PM
95stroke's Avatar
Be careful using a screw driver,,don't hit your glowplug relay..
I took that stupid useless black cover off and use a oil filter wrench..same size as your oil filter.
NAPA sells a "Baldwin" made fuel filter with the top attached,,uses a 1/2" socket wrench,no socket.
95stroke is offline
post #7 of 9 Old 06-10-2016, 10:34 AM
Odin's Avatar
Garage
Sorry to bump an old thread but I havnt been able to find by searching.
What is the part number for the fuel filter for a 96 F250 7.3. Is it Motorcraft FD4596? Just want to be sure before I order.
Odin is offline
post #8 of 9 Old 06-16-2016, 07:30 AM
FD-4595
Application: 1994-1997 F-250 through F-550 (50 State)
MeWelding.com is offline
post #9 of 9 Old 06-16-2016, 07:34 AM
Odin's Avatar
Garage
Originally Posted by MeWelding.com View Post
FD-4595
Thank you sir! Dont know why my searches didn't pull up that thread!
Odin is offline
